Avatars
Aeddon
As I'm sure many of you know already in the avatar settings, 'Space Marines' section you are able to select from several different chapters and in the case of the Ultramarines, different companies as well (UM have 20 choices in all in this section!). Space Wolves on the other hand can only choose between 13th Company, Ragnar's Great Company and a Space Wolf that (IMO) looks like he's pressed up against the rear-window in a thunderhawk. I would like to see more options for the other Great Companies in our chapter.
Does anyone else out there feel the same way? ;)
Would you like to proudly show off your colors? ;)
Or did I just get a bad batch of mead before posting this? :sweat:
https://bolterandchainsword.com/topic/204194-avatars/
I agree. Do you think there is a way to reduce the SW in the Bolter and Chainsword Banner (SW Skin) to avatar size?
Though I have to admit I really like Hrathnar Flintfang's avatar:
http://img3.imageshack.us/img3/5331/truewolvese.jpg
I have it saved as one of my wallpapers :sweat:
https://bolterandchainsword.com/topic/204194-avatars/#findComment-2434633
I really like mine, it's on the Lexicanum page for Space Wolves. It's just a general Wolf, no Great Company markings, just the chapter marking.
Although I would like a better Ragnar's one.
I might be mistaken but the black shoulder pad looks like Logan Grimnar's Great Company from before he became Great Wolf.
https://bolterandchainsword.com/topic/204194-avatars/#findComment-2434676
I think it is the Great Wolf marking, The wolf who stalks the stars. Grimnar´s pre-GW marker was just a wolfhead howling at a moon.
https://bolterandchainsword.com/topic/204194-avatars/#findComment-2434769
The anime bolter-babe is definitely cool; here is mine. It took me a while to find, but I really like it. The thumbnail doesn't really do it justice.
Stand-by...image posting malfunction... :)
In the meantime, here is the link to the full size:
http://img180.imageshack.us/img180/8934/da...verartv2ke7.jpg
https://bolterandchainsword.com/topic/204194-avatars/#findComment-2434960
I fragged a few images that have been displayed as avatars in this discussion, though there are a few others that need attention.
The first issue members have to consider is the dimensions of their avatar. The avatar settings allow for images up to 96 pixels in height by up to 64 pixels in width. If you use a larger image, it will be re-sized. However, larger dimensions often lead to larger file size. While the forum rules don't specify maximum file size, having anything that exceeds a couple hundred KB leads to problems for some users and slows down download times. Expect to see the forum rules changed to reflect a maximum image file size for avatars very soon.
The second issue to remember is that members are not allowed to hot-link from third party sites. The two avatars that were fragged were hit primarily for this issue - one hot-linked from Fantasy Flight Games' site and the other hot-linked from Lexicanum. The B&C doesn't allow hot-linked from other sites as a basic web courtesy. We don't want to put a burden on other sites' servers. We also provide members with a very handy way of avoiding this - you can easily create your own free gallery here at the B&C. Alternately, you can use an image hosting site such as Photobucket or Imageshack.
The best thing to do with avatars is to size them to something within the maximum allowed display dimensions of 96x64. This ensures WYSIWYG and, more importantly, usually suffices to get the file size down to something acceptable for all members. And then I highly recommend using your own free B&C gallery to host the image, though you are free to use other image hosting sites if you prefer.
Per the member's question above, I'll see about turning that Space Wolf image from our banner into an avatar. I'll look at other banner images we have for similar treatment.
https://bolterandchainsword.com/topic/204194-avatars/#findComment-2435369
Here are two versions, both developed by simply cropping the image to something 96x64 pixels. The first has a border (using what I thought was the unmodified color of the diamond-shaped gem on the Space Wolf's chestplate) and the other is sans border. Is that what you're looking for, or were you looking at some other shape such as wider in order to get more of the image in? If so, the height will be shorter since the baseline banner is just a little taller than 96 pixels.
Okay, looking at that border it appears to be more pastel/pink than the gem appears. I'll fix that. Here it is (perhaps a little too bright).
Also note that the images are in my personal gallery, so please don't use them. Once I have an image that y'all like, I'll put it in the baseline avatar gallery for public use (and delete these from my gallery).
https://bolterandchainsword.com/topic/204194-avatars/#findComment-2435385
You mean like they did for my banner?
That's what I said.
That's what I said.
That's what I said.
That was an accident by the way.
I thought you were just trying to be funny B)
https://bolterandchainsword.com/topic/204194-avatars/#findComment-2436138
could the avatars from the space marine avatar pictures be changed with great company's? like there is Ragnars and the 13th.
You can download both the blank avatar and the various company badges from the download area. If you can create a decent avatar out of that we have no issues with adding it to the choices.
https://bolterandchainsword.com/topic/204194-avatars/#findComment-2436196
cool ill have to try that.
https://bolterandchainsword.com/topic/204194-avatars/#findComment-2436216
