How would your best 5 man Thunderwolf cavalry geared like?
djoguit
Not quite - you can allocate wounds to individual models rather than having to group like-armed models together.
Say you had 3 TWC
You then take eight hits which, as it happens, results in five wounds.
If they were all identical then you would roll all five die together. In this example, you make three saves so loss a model.
If they are differently armed then you can allocate one wound to each one, and then double up on two of then.
You have a better chance of making at least one of those saves per model and taking the two wounds on different models - thus keeping all three in play.
Sorry for the stupid questions but say for example I have a round of combat I suffer a wound and its not saved I put that wound on a TWC with a PW
Next round I suffer another unsaved wound can I put that wound on a different wolf or do I have to take it on the original PW armed TWC meaning he is dead?
Don't worry, it's not a stupid question as this is something that has changed under v.5.
You can allocate the wound to any of them, but it must be allocated before you try for the save:
They roll to hit, they roll to wound, you allocate, you roll any saves you may have, unsaved wounds are then applied and figures removed as required.
