Nagatamarines Posted June 24, 2010 Share Posted June 24, 2010 Hey again guys. I have a few questions about painting, if any of you could help answer em. 1. Should the primer be applied outside? Or is it OK to use it in an area with air vents? 2. This one isn't exactly a question, I guess. Is painting details difficult if you are decent at drawing, or should I have some painting experience before? EDIT: Question 3 removed. Anymore worthless posting of that nature and you will find yourself with a warning. Link to comment https://bolterandchainsword.com/topic/204986-general-questions/ Share on other sites More sharing options...
Terminatorinhell Posted June 24, 2010 Share Posted June 24, 2010 1. just use it as the can says in a well ventilated area, go outside! 2. Details actually require painting experience, painting is pretty different from drawing so it might help to learn a bit more about paining. 3. That was unnecessary Link to comment https://bolterandchainsword.com/topic/204986-general-questions/#findComment-2444786 Share on other sites More sharing options...
Nagatamarines Posted June 24, 2010 Author Share Posted June 24, 2010 Thanks for the help, and yes, that was completely unesscery. :pinch: Almost got a warning from a mod. Now to do it again for a warning. EDIT: Ahh so you want to go down that road. That is fine. Comments removed. Warning issued. Better start following the forum rules or you won't be here long. Link to comment https://bolterandchainsword.com/topic/204986-general-questions/#findComment-2444813 Share on other sites More sharing options...
