JAW
Torin
Good day brother,
I need answers for the following question. Because its becoming a debate at the moment at my current store.
Jaws of the World Wolf says: Draw a 24" straight line 'along the board' and may through terrain. Any models touched take Init test.
1. does along the board means the line must be on the table and i can't touch models on 1st floors of a ruin?
2. how bout models in a bunker?
3. most importantly can i draw the line in such a way that it touches my units as well? not purposely of course.
https://bolterandchainsword.com/topic/205303-jaw/
This is covered in multiple topics, that your friend Searchy the servo skull is more than willing to help with. And he WANTS to help you...
Jaws of the World Wolf...
1. For this, refer to standard geometry. Lines that gain height or width become rectangles and cease to be lines. Along the board means flat on the table, you can't aim it into a building's upper levels. Those on the ground floor can be hosed though.
2. It passes through terrain, which bunkers are. If some guys are hiding in there, and the line would cross them, they too take the test.
3. Whatever the line touches takes the test, regardless of whose side they are on. Accidents happen when the wolf is hungry.
Remember, the fluff of JotWW is that the ground (table) splits open briefly to swallow the slow and unexpectant before swiftly closing to entomb all that fell.
https://bolterandchainsword.com/topic/205303-jaw/#findComment-2448618
It can go through combat but the first target model can't be in combat.
Space Wolf Errata -
Q. Does Jaws of the World Wolf allow the Rune
Priest to target specific models within squads?
A. Yes.
Q. How wide is the line for the Jaws of the World
Wolf power?
A. It’s a hairline, it does not really have a specific
designated thickness. We like to turn our tape
measures on one side and use their edge,
keeping it as straight as possible of course.
Q. Does Jaws of the World Wolf require line of
sight? Does it ignore terrain that blocks line of
sight (i.e., impassible terrain)?
A. As a psychic shooting attack, Jaws of the World
Wolf requires line of sight. The Rune Priest must
have line of sight to the first model that the
power affects – in effect he is treated as the target
model; the power just happens to hit everybody
else on its way through!
This means that the first target model can't be in combat as per shooting attacks but anything else along that 24" line can be.
At least that was my understanding.
https://bolterandchainsword.com/topic/205303-jaw/#findComment-2448856
no save except for maybe wolf tail talisman or some sort of psyker defense. armour and invulnerable saves will not save you from a a giant hole in the ground. only jet packs, skimmers, and a special anti psyker ability that keeps the ground from opening up under you.
at least thats what i think.
https://bolterandchainsword.com/topic/205303-jaw/#findComment-2449053
Good day brother,
No, the line is only along 'ground level'. It cannot go up the sides of buildings. The only terrain the line should be able to go 'up' are hills which are, in my group at least, treated as being the table top.
No, models in bunkers are not actually placed in most situations in a similar way to embarked models. The rules for bunkers also state that models inside cannot be targetted so would beunaffected by the power.
Yes, as has been said the first model affected has to be within LOS, range, out of combat and an enemy model. After that the line continues for the duration of its length affecting any models under the line friend or foe.
Also as has been mentioned no saves of any kind are allowed as the power doesn't cause wouns, it simply removes a model from play. Some psychic defences would work, but there aren't many that do much outside making the power harder to cast. WTT are the only thing i can think of that would prevent casualties.
https://bolterandchainsword.com/topic/205303-jaw/#findComment-2449071
well some people dont agree with your second answer. they mention that bunker are treated as vehicle, so is not capable of harming unit in a bunker.
These people are correct. Units inside vehicles (and by extension intact buildings like bunkers) are safe.
Going back over, yup. Forgot guys in bunkers and such buildings get removed from table as per vehicles. (p.79 BRB) 2/3 ain't bad for late night with no book. :)
https://bolterandchainsword.com/topic/205303-jaw/#findComment-2449172
Going back over, yup. Forgot guys in bunkers and such buildings get removed from table as per vehicles. (p.79 BRB) 2/3 ain't bad for late night with no book. :sweat:
sorry hmk17, i dont get what you mean. "Forgot guys in bunkers and such buildings get removed from table as per vehicles". so you telling me that it JAW effect the unit or not.
cheer.
https://bolterandchainsword.com/topic/205303-jaw/#findComment-2449415
Going back over, yup. Forgot guys in bunkers and such buildings get removed from table as per vehicles. (p.79 BRB) 2/3 ain't bad for late night with no book. :(
cheer.
not affected as they aren't on the table (as a unit in a vehicle is not affected)
https://bolterandchainsword.com/topic/205303-jaw/#findComment-2450134
Since this thread is up anyway, when casting JotWW from a vehicle, do I measure from the hull, as with other shooting?
It would be measured from the fire point not the hull as per the normal rules for models shooting from a transport.
Only powers/abilities which are area of effect such as BAs Blood Chalice, or Stormcaller/Tempests Wrath etc are measured from the hull.
https://bolterandchainsword.com/topic/205303-jaw/#findComment-2450335
