Pigeons Posted July 1, 2010 Share Posted July 1, 2010 can anyone give me info on the order? other than horus being the first, i'm really not sure. Link to comment https://bolterandchainsword.com/topic/205482-order-the-primarchs-were-found-in/ Share on other sites More sharing options...
isilvra Posted July 1, 2010 Share Posted July 1, 2010 Angeron was found after Perturabo. Theres a few more clues in the tales of Heresy book but I don't have it to hand right now. Link to comment https://bolterandchainsword.com/topic/205482-order-the-primarchs-were-found-in/#findComment-2451331 Share on other sites More sharing options...
Pigeons Posted July 1, 2010 Author Share Posted July 1, 2010 yeah it doesn't seem like there's much to go on with figuring out the order i'm up to tales of the heresy and haven't really seen anything Link to comment https://bolterandchainsword.com/topic/205482-order-the-primarchs-were-found-in/#findComment-2451333 Share on other sites More sharing options...
Rider-75 Posted July 1, 2010 Share Posted July 1, 2010 alphariusomegon was last. Link to comment https://bolterandchainsword.com/topic/205482-order-the-primarchs-were-found-in/#findComment-2451341 Share on other sites More sharing options...
isilvra Posted July 1, 2010 Share Posted July 1, 2010 Logic would suggest that those found closer to Terra would be discovered sooner rather than later. Corex landed on a world that had already joined the imperium, or so I remember reading some place. Dorn was found some 40 or more years after he landed in the Inuwit cluster. Fulgrim was Night Haunters mentor. Lorgar was found after Magnus since Mangus was with the emperor at the meeting. Theres a fair few of these little bit around. Some day we may have enough to compleate the order. Link to comment https://bolterandchainsword.com/topic/205482-order-the-primarchs-were-found-in/#findComment-2451344 Share on other sites More sharing options...
Branek Icefang Posted July 2, 2010 Share Posted July 2, 2010 I don't think they have a GW have released a definitive list, but I thought their legions numbers were the order they were found in? Like, Lion was first and Alph/Omeg was last? Link to comment https://bolterandchainsword.com/topic/205482-order-the-primarchs-were-found-in/#findComment-2451530 Share on other sites More sharing options...
Pigeons Posted July 2, 2010 Author Share Posted July 2, 2010 no, the legions were created before ANY of the primarchs were found to lead them. originally the emperor just led them all. horus was found first. Link to comment https://bolterandchainsword.com/topic/205482-order-the-primarchs-were-found-in/#findComment-2451549 Share on other sites More sharing options...
Hiram Posted July 2, 2010 Share Posted July 2, 2010 I believe Lion'el Johnson was found after Jaghatai and of Course Horus if that helps at all (His first deployment with his legion was to relieve the White Scars in a protracted war of compliance). Link to comment https://bolterandchainsword.com/topic/205482-order-the-primarchs-were-found-in/#findComment-2451632 Share on other sites More sharing options...
Priest33 Posted July 2, 2010 Share Posted July 2, 2010 Legion listing has no connection to when the Primarchs where found. The list goes like this: 1st) Horus here) stuff Last) Alpharius I doubt they will release an exact timeline as they would force them to mention the 2 unkown primarch's and thats just bad. Link to comment https://bolterandchainsword.com/topic/205482-order-the-primarchs-were-found-in/#findComment-2451676 Share on other sites More sharing options...
Hiram Posted July 2, 2010 Share Posted July 2, 2010 This is probably Overly Simplistic but by Looking at the distance from Terra (as the crow flies) and the small amount of known information presented the following seems to be a possible starting point; Possible Order Horus - Cthonia Magnus - Prospero Leman Russ - Fenris Jaghatai Khan - Chogoris Lion'el Johnson - Caliban Vulkan - Nocturne Sanguinius - Baal Corax - Deliverance Roboute Guilliman - Macragge Alpharius - ? Unknown Angron - ? Conrad Kurze - Nostramo Ferrus Manus - Medusa Fulgrim - Chemos Lorgar - Colchis Mortarion - Barbarus Perturabo - Olympia Rogal Dorn - Inwit Link to comment https://bolterandchainsword.com/topic/205482-order-the-primarchs-were-found-in/#findComment-2451734 Share on other sites More sharing options...
Pigeons Posted July 2, 2010 Author Share Posted July 2, 2010 from reading tales of heresy i get the impression that the Lion was found very late in the crusade check these lines from "Call of the Lion": "in the early years the forces of the Great Crusade had met with huge success, bringing the imperial truth to hundreds of worlds in the relatively densely populated systems around Terra. Here, in the yawning chasm between spiral arms, such colonies had always been sparse, and through the isolation of the Age of Strife it was possible that none at all had survived." now this gives us a good established time line, seeming to indicate that the story takes place well into the Great Crusade, probably just before the time of Istvaan III. now combine that with this tidbit: "Astelan knew nothing of Belath, but these days that was not surprising. The massive influx of warriors into the Legion following the rediscovery of Caliban meant that there were many commanders who had never met each other, tossed together on task forces and in warzones all across the galaxy." the two together would seem to imply that the story takes place late in the Crusade, and that Caliban,and thus the Lion, were only recently discovered. but maybe i'm reading way too much into that. edit: you're wrong about some others, too. from the last story in tales of heresy "after desh'ea", we learn that both vulkan and perturbo were found before angron, although it doesn't specify which order the two were found in. the order they TALK about them is vulkan and then perturbo, but that's just the way the story flows, doesn't mean they came in that order. could have been perturbo first and then vulkan five primarchs later for all we know. also, the world eaters were originally called the war hounds, and back when vulkan and perturbo were found they were STILL called the war hounds. which leads me to think vulkan and perturbo were found fairly early on. Link to comment https://bolterandchainsword.com/topic/205482-order-the-primarchs-were-found-in/#findComment-2451947 Share on other sites More sharing options...
