greatcrusade08 Posted July 2, 2010 Share Posted July 2, 2010 Here are my MK2 scouts: http://i708.photobucket.com/albums/ww87/greatcrusade08/003-6.jpg?t=1278084482 http://i708.photobucket.com/albums/ww87/greatcrusade08/002-7.jpg?t=1278084482 Ive made a few changes to the original scout models, ive switched the scout bodies to actual PA (sergeant has MK8) this suits things like power fists but more importantly it enables me to use marine heads as opposed to those poor scout heads. Link to comment https://bolterandchainsword.com/topic/205533-mk2-scouts/ Share on other sites More sharing options...
Zeller Posted July 2, 2010 Share Posted July 2, 2010 That torso change was so subtle I passed over it until I read that last bit of text. Did you have to greenstuff any bits up to fit properly or did you shave down the torso in areas and it popped right on? Link to comment https://bolterandchainsword.com/topic/205533-mk2-scouts/#findComment-2452019 Share on other sites More sharing options...
greatcrusade08 Posted July 2, 2010 Author Share Posted July 2, 2010 No greenstuff was used in the making of this model :) seriously though it does take alot of trimming i remove most of the PA belt but leave the buckle and then remove the buckle from the scout waist so it sits flat.. the worst scout legs are the ones with the pouches and holsters that stick above the wasitline, it requires a lot more trimming Link to comment https://bolterandchainsword.com/topic/205533-mk2-scouts/#findComment-2452030 Share on other sites More sharing options...
Terminatorinhell Posted July 2, 2010 Share Posted July 2, 2010 Time do redo my scouts lol, do you mind if I borrow this method? Link to comment https://bolterandchainsword.com/topic/205533-mk2-scouts/#findComment-2452258 Share on other sites More sharing options...
greatcrusade08 Posted July 3, 2010 Author Share Posted July 3, 2010 Time do redo my scouts lol, do you mind if I borrow this method? No mate, its free to all.. let me know if you have any problems it can get quite tricky.. the key is not to remove the belt completely but leave a couple of mm's and then shave it flat. Link to comment https://bolterandchainsword.com/topic/205533-mk2-scouts/#findComment-2452602 Share on other sites More sharing options...
W.A.Rorie Posted July 3, 2010 Share Posted July 3, 2010 Thanks GC08 now i know how I am building my last scout squad. Link to comment https://bolterandchainsword.com/topic/205533-mk2-scouts/#findComment-2452609 Share on other sites More sharing options...
greatcrusade08 Posted July 3, 2010 Author Share Posted July 3, 2010 no worries.. i was wondering if anyone can guess from this pic what bits i used: http://i708.photobucket.com/albums/ww87/greatcrusade08/002-7.jpg?t=1278084482 legs: standard scout legs torso: ?? head: ?? left arm: ?? right arm: ?? Link to comment https://bolterandchainsword.com/topic/205533-mk2-scouts/#findComment-2452624 Share on other sites More sharing options...
rat of vengence Posted July 3, 2010 Share Posted July 3, 2010 Lets see here... legs: standard scout legs torso: Mk 8 sergeant armour from the tactical box head: Spacewolf head? left arm: Assault sergeant powerfist right arm: scout from LSS, guy hanging on the right hand side. I have the same bit spare, I used the old metal scout biker boltgun with drum mag. Nice work GC08, I may do the same. It bulks them out very well, and looks like it 'should' be there :cry:. RoV Link to comment https://bolterandchainsword.com/topic/205533-mk2-scouts/#findComment-2452646 Share on other sites More sharing options...
greatcrusade08 Posted July 3, 2010 Author Share Posted July 3, 2010 legs: standard scout legs torso: Mk 8 sergeant armour from the tactical box head: Spacewolf head? left arm: Assault sergeant powerfist right arm: scout from LSS, guy hanging on the right hand side. I have the same bit spare, I used the old metal scout biker boltgun with drum mag. not a bad guess, the left arm is actually a lightnening claw from the SM commanders set that i converted, the head is the commander culn one. thanks for the positive comments so far, i agree the PA looks like it should be there. Link to comment https://bolterandchainsword.com/topic/205533-mk2-scouts/#findComment-2452650 Share on other sites More sharing options...
Lorenzen Posted July 3, 2010 Share Posted July 3, 2010 im wondering about the back of the models.. have you cut down the bit that joins the power back to the marine? id suggest either doing so, converting some scout armour esque stuff or adding some backpack related goodness to cover the back area. other than that id consider doing the "knuckle duster" on the sarge in metallics, but thats just me. nice work. :) Link to comment https://bolterandchainsword.com/topic/205533-mk2-scouts/#findComment-2452730 Share on other sites More sharing options...
greatcrusade08 Posted July 3, 2010 Author Share Posted July 3, 2010 i cut down the knob that attaches the backpack Link to comment https://bolterandchainsword.com/topic/205533-mk2-scouts/#findComment-2452739 Share on other sites More sharing options...
