swooshfinn Posted July 6, 2010 Share Posted July 6, 2010 So I am reading through my C:SM and I am a bit perplexed at the entry for Moonfang. The way its worded, it seems as if the Moonfang is a relic weapon, not just a standard power weapon. Here's the entry just in case you have forgot or don't have a Codex handy: "This ancient power sword is a relic of the White Scars Chapter..." The guy I normally play against just says its a power weapon, but if you read the entry for relic weapons in the same Codex it states: "Relic blades are two-handed swords or axes sheathed in an armour-sundering power field. Most have their origins in the dark day of the Horus Heresy, although some have been crafted in the long centuries since, in commemoration of other momentous events." In further evidence, I would like to point out that the Kahn model that is not on a bike, is actually weilding a two-handed sword that is being held over his head in a power strike pose. I might be wrong, but I think the evidence clearly points to the fact that the Moonfang is actually a relic weapon, not just a power weapon. Link to comment Share on other sites More sharing options...
Tanhausen Posted July 6, 2010 Share Posted July 6, 2010 I'd say that if the codex does not consider it a relic weapon (in its description, as in crafter armours and such), then its "only" a power weapon... because I'm assuming it DOES say it is a power weapon in the weapon description ... because if it doesn't say that either, then its just a normal close combat weapon :huh: I'll have a look tonight just for curiosity. Link to comment Share on other sites More sharing options...
Rider-75 Posted July 6, 2010 Share Posted July 6, 2010 without the codex to refer to, i'm afraid i'd read it as a power weapon from your quote. "This power weapon......" rather than: "This relic blade..." Power weapon is a class of weapon,as is relic blade. as it says power weapon in the description, i'd say that's what it is. Link to comment Share on other sites More sharing options...
Grey Mage Posted July 6, 2010 Share Posted July 6, 2010 Power Swords are powerweapons, generally speaking. This is exactly what Moonfang is. However, if you seriously try to call it a relic blade expect to have it act as a normal close combat weapon- because the rules for power weapons never mention "power swords", and Moonfang never says in and of itself that it ignores armor saves. Take the power weapon ability and get on with your game. Link to comment Share on other sites More sharing options...
ShinyRhino Posted July 6, 2010 Share Posted July 6, 2010 It's just a power weapon that causes ID on to-wound rolls of a 6. It's the tradeoff you make for gaining Furious Charge, and Hit and Run. Link to comment Share on other sites More sharing options...
nurglez Posted July 6, 2010 Share Posted July 6, 2010 A blade weapon that is also a relic, is not a relic blade. Almost all space marine power weapons are considered relics, as, well, they are very old :D Link to comment Share on other sites More sharing options...
Leonaides Posted July 6, 2010 Share Posted July 6, 2010 Technically Dnate's Axe Mortalis is a relic blade - but in game terms its definatley a master-crafted Power Weapon, not a Relic Blade. Link to comment Share on other sites More sharing options...
greatcrusade08 Posted July 6, 2010 Share Posted July 6, 2010 Its a minor misunderstanding.. just becuase something is described as a relic weapon doesnt mean its a relic blade in the rules sense. There are no rules for relic weapons only relic blades by RAW Link to comment Share on other sites More sharing options...
Acebaur Posted July 7, 2010 Share Posted July 7, 2010 Its a minor misunderstanding.. just becuase something is described as a relic weapon doesnt mean its a relic blade in the rules sense. There are no rules for relic weapons only relic blades by RAW Getting into semantics on something like this can get sticky. If it were to count as a Relic Blade then it would have said so instead of calling it a power sword. Link to comment Share on other sites More sharing options...
greatcrusade08 Posted July 7, 2010 Share Posted July 7, 2010 Getting into semantics on something like this can get sticky. If it were to count as a Relic Blade then it would have said so instead of calling it a power sword. :) I believe thats what i was saying?? maybe i should have been clearer. It describes the weapon as ancient relic, NOT a relic blade. heres a quote from the codex: Moonfang: This is an ancient power sword and relic of the white scars chapter... snip there can be no mistaking what this weapon is, it is a power sword Link to comment Share on other sites More sharing options...
