wolf363839 Posted July 9, 2010 Share Posted July 9, 2010 Here's the completed armored units of my 2000pt force. Just need to do 2 Thunderwolf Cavalary and all my infantry... Hope you all like 'em. http://i955.photobucket.com/albums/ae39/phil363839/Space%20Wolf%20Army/DSCF2294.jpg?t=1278649365 Link to comment https://bolterandchainsword.com/topic/206045-army-work-in-progress/ Share on other sites More sharing options...
Mithril hound Posted July 9, 2010 Share Posted July 9, 2010 I do. Makes me remember my tank.... Link to comment https://bolterandchainsword.com/topic/206045-army-work-in-progress/#findComment-2457682 Share on other sites More sharing options...
wolf363839 Posted July 9, 2010 Author Share Posted July 9, 2010 Makes me remember my tank.... it's ironic, I was light infantry myself... Link to comment https://bolterandchainsword.com/topic/206045-army-work-in-progress/#findComment-2457694 Share on other sites More sharing options...
Coverfire Posted July 9, 2010 Share Posted July 9, 2010 I am no good with colours... what is your colour scheme? Link to comment https://bolterandchainsword.com/topic/206045-army-work-in-progress/#findComment-2457709 Share on other sites More sharing options...
Mithril hound Posted July 9, 2010 Share Posted July 9, 2010 Makes me remember my tank.... it's ironic, I was light infantry myself... I'm confused to what you mean, I was referring to to my shield adorned predator- which is plastic grey. Link to comment https://bolterandchainsword.com/topic/206045-army-work-in-progress/#findComment-2457829 Share on other sites More sharing options...
Token Posted July 9, 2010 Share Posted July 9, 2010 Good painting, very clean. Closeup of the thunderwolf? How did you do thatone? Link to comment https://bolterandchainsword.com/topic/206045-army-work-in-progress/#findComment-2457901 Share on other sites More sharing options...
CainTheHunter Posted July 9, 2010 Share Posted July 9, 2010 Good painting, very clean. Closeup of the thunderwolf? How did you do thatone? That's Khorne juggernaut conversion. Link to comment https://bolterandchainsword.com/topic/206045-army-work-in-progress/#findComment-2457910 Share on other sites More sharing options...
Token Posted July 9, 2010 Share Posted July 9, 2010 What about the head? Link to comment https://bolterandchainsword.com/topic/206045-army-work-in-progress/#findComment-2457990 Share on other sites More sharing options...
Valerian Posted July 9, 2010 Share Posted July 9, 2010 Makes me remember my tank.... it's ironic, I was light infantry myself... I understand the irony - I was a tanker/cavalryman for 10 years, but only recently started using a single tank (a standard Land Raider) to my previously all footslogging (dismounted infantry) Space Wolves force. The only other "vehicles" I have every used are Dreadnoughts. Valerian Link to comment https://bolterandchainsword.com/topic/206045-army-work-in-progress/#findComment-2458015 Share on other sites More sharing options...
wolf363839 Posted July 9, 2010 Author Share Posted July 9, 2010 to Token: that's my bloodcrusher conversion into a thunderwolf. hopefully a plastic version of the bloodcrusher is coming out in August, which will be easier to convert and build than this metal one. I trimmed as much of the "chaos-y" stuff off the model as I could, and added 2 tyranid chiten pieces for the "ears". This has been discussed many many times, but it's just my personal preference to use a mechanical beast instead of an unarmored wolf for my Thunderwolf models. (also, since it is a GW model, I'm allowed to use it for gaming at the GW store I frequent). Color scheme: the pick is too large, so I'll add some close ups. I primed them in Krylon Grey Primer (found at your local Walmart or Home Depot). I then washed Badab Black into every recess. Then drybrushed/overbrushed Adeptus Battlegrey (nearly perfect match to the Krylon Grey) over the whole model, leaving the recesses dark. Finally I "edged" the model using a drybrush/overbrush of Skull White. After all the details were painted, I used 2 coats of Krylon Matte Varnish to seal everything so it won't rub off. It's a fairly simple scheme, just takes a little time. After some practice, I got a lot better at drybrushing the Adeptus, which is key to leaving the recessed areas dark and gives some depth to the look. I also paint my infantry the exact same way. http://i955.photobucket.com/albums/ae39/phil363839/Space%20Wolf%20Army/DSCF2292.jpg?t=1278684272 http://i955.photobucket.com/albums/ae39/phil363839/Space%20Wolf%20Army/DSCF2282.jpg Link to comment https://bolterandchainsword.com/topic/206045-army-work-in-progress/#findComment-2458022 Share on other sites More sharing options...
Welverin Posted July 9, 2010 Share Posted July 9, 2010 I think you mixed the pictures up... they don't look like Metal Beasts.... errr.. not like living Beasts that are armored... Skipp that... they DO! ... But I wouldn't describe them as Thunderwolfcavallary. Link to comment https://bolterandchainsword.com/topic/206045-army-work-in-progress/#findComment-2458039 Share on other sites More sharing options...
MaleOpener Posted July 9, 2010 Share Posted July 9, 2010 An outstanding job, to be sure! Link to comment https://bolterandchainsword.com/topic/206045-army-work-in-progress/#findComment-2458075 Share on other sites More sharing options...
Coverfire Posted July 10, 2010 Share Posted July 10, 2010 Is a different technique required for painting vehicles over infantry? When I painted a burnt out rhino I found that it didn't come up as well as my infantry models. Link to comment https://bolterandchainsword.com/topic/206045-army-work-in-progress/#findComment-2458744 Share on other sites More sharing options...
Hotspur Posted July 10, 2010 Share Posted July 10, 2010 Those look great! I really like the sharp contrast between the main color and the highlights on the hard edges. Keep up the good work. Link to comment https://bolterandchainsword.com/topic/206045-army-work-in-progress/#findComment-2459160 Share on other sites More sharing options...
Warhorse47 Posted July 10, 2010 Share Posted July 10, 2010 Very nice work Brother! Link to comment https://bolterandchainsword.com/topic/206045-army-work-in-progress/#findComment-2459173 Share on other sites More sharing options...
Wysten Posted July 10, 2010 Share Posted July 10, 2010 Awesome work! The sort of thing I will try and aspire up to once I start painting stuff. The only problem might be that it looks too clean, I dare say it may not be so after a few field "tests" by our "professional" blood claws! XD Link to comment https://bolterandchainsword.com/topic/206045-army-work-in-progress/#findComment-2459190 Share on other sites More sharing options...
