Prime again?
I've stripped my Marines, who were primed with black mind you, and you'll never get it ALL off. There will always be some in nooks and crannies, and the plastic will have a sort of permanent black 'patina'. Don't worry, when you reprime, it will be as if the last paintjob never happened. Even if you go from black prime to white prime.
https://bolterandchainsword.com/topic/206099-prime-again/#findComment-2459824
What are you using to strip your models? and are they plastic or pewter?
As previously mentioned you never can get all of the old paint off, especially if it's a plastic model.
Now if it was a pewter model I would argue other wise for I have stripped my models clean after soaking them for 12 hours or so in acetone, and the results are stunning.
https://bolterandchainsword.com/topic/206099-prime-again/#findComment-2461558
