perfectionist Posted July 14, 2010 Share Posted July 14, 2010 Hi all! Another one of my finished minis I'd like to share with you. This one was quite interesting since it is the first non-plastic model I attempted, the first one with a banner and the first one I "converted" (I actually only cut the left arm bolt pistol and converted a right arm power axe to that cut arm, but I guess it still counts as a conversion ;)) I have to say that working with metal models is quite different from the plastic ones. When I started on this one, chipping paint was a problem. Eventually I added a thin coat of dull clear coat in between steps, which actually solved that problem fairly well. Also mold line removal is quite a pain for the metal models imho. Especially there is one on the hood of his cloak on the left side which I had to leave since filing it would have destroyed all the detail. Secondly I attempted to freehand the banner. I am pretty pleased with the result, but there is obviously room for improvement. I kept the design simple and 2D for starters. But I guess practice makes perfect :) The banner itself is made from a piece of kleenex. I read in a tutorial that kleenex resembles cloth once painted and I have to agree with that. Now for the pictures. C&C as always is more than welcome. Cheers, Perfectionist http://i1003.photobucket.com/albums/af151/fiddler6291/DAs%20a%20start/standard%20bearer/P7121878_klein.jpg http://i1003.photobucket.com/albums/af151/fiddler6291/DAs%20a%20start/standard%20bearer/P7121876_klein.jpg http://i1003.photobucket.com/albums/af151/fiddler6291/DAs%20a%20start/standard%20bearer/P7121877_klein.jpg Link to comment Share on other sites More sharing options...
Isiah Posted July 14, 2010 Share Posted July 14, 2010 I think you've made an excellent job -- it's a very good DA standard bearer ;). The colouration of the armour and the approach you've used on the robe is working really well. I haven't seen the tutorial you mention on using Kleenex as a basis for banners, but, looking at the results I'd say it was both too absorbant and too textured to enable accurate designs to be painted on at this small a scale and level of detail. Plus cutting it cut results in too broken an edge due to the fibres in the paper. Just my opinion of course. Cheers I Link to comment Share on other sites More sharing options...
fivepointedstar Posted July 14, 2010 Share Posted July 14, 2010 is a gret job in the painting. the robe really looks worn, and flowing. Even thou the banner is a bit coarse its still work-a-ble. keep up the good work Link to comment Share on other sites More sharing options...
