How do you base properly?
Hi, basically later this holiday i plan on basing my entire army. I've got the PVA glue and the Burnt Grass Flock (i have sallies so it makes sense).
But to me it wouldn't work just having burnt grass on a black base. because it wouldn't look much different.
so what do you guys do, do remedy the situation?
thanks in advance
Athiair :lol:
https://bolterandchainsword.com/topic/206484-how-do-you-base-properly/
I second this. Someone on my estate had a huge pile sat in their garden a while ago, I asked if I could pince some and the plastic tub full has lasted me for ages. Granted I don't actually finish my mini's that often but when I do I use sand and slate ( which I got for free from a friend who works in construction <_<)
James
GW has various tutorials on basing you might want to check out.
http://www.games-workshop.com/gws/content/...23a&start=4
(might have to log in first)
Sand is near free, glue is cheap, and you can also find very small rocks, glue those to the base, and paint/drybrush them.
thanks lord gunter. it sounds good, do you have any pictures of it? it would be nice to see it.
i just need to buy bestil brown and snake bite leather. i think i've got scoched brown.
and i'll keep looking for sand :)
thanks for all your help guys
Athiair :P
I actually apply the sand and other base material before I prime.
the primer will help any small lose bits stick as well
once the sand is painted then I flock with the static grass ( if required )
also note: if you are going to have large objects ( helmets, rocks, or other ) on the base glue it down FIRST before the sand is added
