useing fantasy choas warriors as space marines
most people just use the legs of chaos warriors, ive seen somewhere where somebody used a chaos warrior cape on a chaos lord. but he had to use tonnes of green stuff. but thats pretty much all ive seen for chaos warrior conversions to 40k.
There is a so called true-scale 'pattern' that uses the back part of the chaos warrior (as mentioned above) with the legs and cloak and uses the front half of a space marines torso. Look for Doghouse pattern... (he has done some newer ones based off terminators I think but you should be able to find the warrior ones...)
I've also used Chaos space marines used as Fantasy Chaos Warriors :D
