lord gunthar Posted July 18, 2010 Share Posted July 18, 2010 Can you assault the contents of a vehicle after wreaking/exploding it in the shooting phase, with the squad that destroyed the vehicle ? On pg 67 of the BRB it states , regarding the effects of results on passengers Note: remember that all models in a single unit fire simultaneously, so a squad cannot take out a transport with its lascannon and then mow down the occupants with its bolters. However,if a transport is destoyed (either result) by a ranged attack, the unit that shot it may assault the now disembarked passengers, if it is allowed to assault according to the assault rules. Now according to the assault rules on pg 33 just after Disallowed assaults In addition to the above, a unit that fired in the shooting phase can only assault the unit that it shot at - it cannot assault a different unit to the one it previously shot at. Transport vehicles are a seperate unit to the squad that is embarked inside. Am I missing something or do these rules contradict each other, and have I been wrong about this rule all these years ? Link to comment Share on other sites More sharing options...
Chengar Qordath Posted July 18, 2010 Share Posted July 18, 2010 The case of units inside a transport is listed as an exception to the general shooting -> assault rule, so a unit that blows up a transport via shooting can assault its occupants. Link to comment Share on other sites More sharing options...
Mordekiem Posted July 18, 2010 Share Posted July 18, 2010 Note the page numbers. You are reading them in the wrong order. read pg 33 first. then note the exception on pg 67. Also, it does not matter if the transport is dedicated or not. Link to comment Share on other sites More sharing options...
rat of vengence Posted July 19, 2010 Share Posted July 19, 2010 As long as you didn't use a heavy or rapid fire weapon to crack the transport you are good to go. RoV Link to comment Share on other sites More sharing options...
Albion de Heaven Posted July 21, 2010 Share Posted July 21, 2010 As long as you didn't use a heavy or rapid fire weapon to crack the transport you are good to go. RoV Unless you are rentless or have some other special rules that allows you to fire heavy weapon/rapid fire and charge :) Link to comment Share on other sites More sharing options...
