Razorback Turret-Mounted Weapons
http://i180.photobucket.com/albums/x277/greendestiny_bucket/CIMG1761.jpg
http://i180.photobucket.com/albums/x277/greendestiny_bucket/CIMG1763.jpg
http://i180.photobucket.com/albums/x277/greendestiny_bucket/CIMG1762.jpg
http://i180.photobucket.com/albums/x277/greendestiny_bucket/CIMG1760.jpg
http://i180.photobucket.com/albums/x277/greendestiny_bucket/CIMG1759.jpg
http://i180.photobucket.com/albums/x277/greendestiny_bucket/CIMG1758.jpg
I know it is supposed to be a twin linked Plasma gun not a cannon but I felt this represented a turret mounted weapon better than the standard size plasma guns that just look too small and week.
My concept behind it is that it is larger more sophisticated tech improving it's accuracy rather than just having two guns giving you a reroll.
  • 2 months later...
  • 2 weeks later...
  • 2 weeks later...
  • 2 weeks later...
Here's how I do mine, the plasma guns are just standard plasma guns chopped down to the end of the 'coil' part on the top, and fitted into the razorback lascannon part. I chop the barrel of the lascannon off and most of the support underneath. Takes a bit of filing to get the parts to fit snugly but it's a 20 minute conversion at most.
this is by far my favourite double plasma/lascannon conversion. A+
Start with These:
Chop bits of 2 Plasma guns, file flat the two mating sides and glue together, file flat bottom and rear faces. Drill 2mm hole and pop in 2mm magnet (use superglue, careful mind!!)
Cut Las cannon down last groove as shown as shown
And 2 lower horizontal connections to end up with this.File flat and square all mating faces
Drill and glue in magnet as shown. This single magnet will hold the Las cannon barrel no probs.
Stick a further magnet in down the horizontal support as shown if desired. (gives a bit more stability for plasma guns)
Put a magnet in the barrel connecting face. And you have a TLLC loadout
Pop the Plasma Guns on and you have a different load out
Closer view
  • 3 weeks later...
I'm planning on doing one that is just two Plasmaguns on either side of an Icarus Lascannon, with tubing leading from the Plasmaguns into the under part of the Icarus. I've also made a TL Assault Cannon top by cutting up the quad gun mount from the Defence Line kit and attaching the TL Assault Cannons from the Ravenwing box set. I'll get pictures up when I can.
  • 1 month later...
any opinion on if the twin plasmaguns have to be mounted with the lascannon? Or would it be possible/OK to do a single lascannon with the twin PG mounted on the cupola in place of where the rhino storm bolter goes?
On the one hand, I can see folks thinking that's a cheesy way of getting a couple extra inches on the range of the TPG. On the other hand, the recent FAQs do indicate the LC and TPG are separate weapons.
It states they are seperate weapons for the purpose of determining "Weapon Destroyed" results on the damage table. If you read the entry for a Razorback on page 77 of Codex SM it says "...sacrifices a portion of it's transport capacity for turret-mounted armament, normally a Twin-linked Lascannon or Heavy Bolter". In the army lits on page 135 under Dedicated Transports in the Options you may replace TL Hvy Bolters with...
It specifically states the weapon system is turret mounted. I've seen one guy on the BoLS website that mounted the Plasma guns in the cupola for the extra "cheesy" couple of inches (if that). Man, did he come under some flak :) Looks crap in my opinion.
  • 5 weeks later...
Here's the conversion unpainted I did recently, not that I did it for "extra inches" just wanted the convenience of taking one or the other weapon off. The thought of it having a game effect didn't really occur to me. I'll get some pics of it painted up later if I can, I think it came out pretty well. Wasn't using those Ironclad HK missle shrouds anyway!
http://is100.imagesocket.com/thumbs/2011/02/22/2jpgw4no.jpg
http://is100.imagesocket.com/thumbs/2011/02/22/7jpghu39.jpg
http://is100.imagesocket.com/thumbs/2011/02/22/9jpgk0u5.jpg
Looks even better painted. So would the extra couple inches upset someone if I put it on a table?
  • 2 weeks later...
I used a pair of old plasma cannons (NO SM tank can have them, so it shouldn't be too confusing for the numpties) and an old lascannon for mine.
With the lascannon centre mounted, just like the original.
As for the TLHF, I used the heavy flamers off the SoB immolator kit. The weapon mounts fit on the razorback turret mounts.
I was alternating immolators and razorbacks at one stage, just to get weapons.
