The_Hunter Posted July 19, 2010 Share Posted July 19, 2010 As the title says you won't be making actual lightning claw terminators but if you ask me it's something even cooler and should be easily noted as not a normal terminator in the end ;) so lets get started this is what we need: http://img46.imageshack.us/img46/7964/dscf0914.jpg - Scalpel (or generic hobby knife just make sure you wear safty glasses as blades tend to break if you put some force on them !) - 2x Terminator Power Weapon (you can use any one of this remember that differences will only spice up things more :) ) - 1 Terminator bolter arm (can use a combi bolter too but those are a little more rare so i would not recommend it!) Optional: - Paperclip and drill (for pinning but this is entirely up to you or not i prefer doing so for added stability) Now lets get started first we cut the cable and power weapon of the one arm like so: http://img32.imageshack.us/img32/4505/dscf0917s.jpg Next were going to do the same with the bolter arm: http://img291.imageshack.us/img291/444/dscf0916j.jpg Now put the power weapon on the other arm like so: http://img46.imageshack.us/img46/6914/dscf0919g.jpg (this is also the part were you would pin the weapon it's not required but i would still recommend it) It can be possible that the arm will not fit right as i noticed fairly quick after making mine so you may want to carefully cut of the hand like this and turn it by a few degrees to make sure he's not hitting himself in the face or leg with the power weapon ;) http://img832.imageshack.us/img832/9341/dscf0922.jpg now carefully put them somewhere to dry as they will be quite fragile untill the glue has set in completly and after that simply put them together on the torso like this: http://img827.imageshack.us/img827/5240/dscf0924.jpg http://img832.imageshack.us/img832/2972/dscf0923.jpg :lol: The rest is up to you how to futher pimp your terminator with the spikes heads greenstuff and who knows what else ;) Link to comment https://bolterandchainsword.com/topic/206764-making-chaos-lightning-claw-termi-proxies/ Share on other sites More sharing options...
WingZ Posted July 23, 2010 Share Posted July 23, 2010 This has given me a awesome idea.. thanks so much.. now to convince the wife i need to buy more bits Link to comment https://bolterandchainsword.com/topic/206764-making-chaos-lightning-claw-termi-proxies/#findComment-2470677 Share on other sites More sharing options...
