Son of Cathal Posted July 20, 2010 Share Posted July 20, 2010 Here is my Emperor's Champion that I am currently in the process of painting. All I've done so far in undercoat, highlight and start the robes Criticism is welcome Link to comment Share on other sites More sharing options...
S. Bloodhowl Posted July 20, 2010 Share Posted July 20, 2010 He's looking good mate. I've just written the below quote in another Black Templar WIP but it works the same here. Because it is black armour i would suggest not highlighting every edge grey but rather using really really dark grey sort of suggest the light reflecting and only use edge highlighting on the points where the light would reflect strongest (eg if the light where coming from above the model, edge highlight the upper edges). The image below should help to explain this, just imagine the light is aimed at the top right corner of the front face. This is a good method on Space Marines because you can use the dark grey in place like down the middle of leg armour etc to suggest lighting, essentially it does what the flash on your camera has Link to comment Share on other sites More sharing options...
