Stripping miniatures using a rock tumbler!
FF151
Hey Guys
Lately I have bought a ton of prepainted miniatures and I have read many topics about stripping miniatures (plastic and metal)
I did an experiment using my daughters rock tumbler and "simple green". I think the results are very promising, have a look at the experiment
This is video 1, there is a 2nd video showing the results later on as well, just locate it in my channel
Hope this helps someone.
FF
I too have had to strip some minis in the past few weeks and found that BAR NONE the best way was to use EASYOFF OVEN CLEANER. I sprayed a bunch in a bowl with a plastic sealed lid I bought at walmart. Completely cover them and let sit for hours,days. It didnt hurt my plastics at all and I have had one in there for a week. Wear gloves though and spray in a well ventilated area, I used an old toothbrush and they came out great.
I use my tumbler for polishing brass.
Paint stripping is accomplished with brake fluid. Dot4 won't harm the plastics (well, not for the short time I have them in it) and strips primer off metals as well as acrylic paint - this will even strip DUCO from cars. Cleanup with soapy warm water and disposal at my neighbourhood mechanic (his disposal drum).
Is this stuff the same as the brand cillit bang in Britain ?? Anyone tried this?
Hey Guys
FF
FF
I loved to rock tumbler idea. It sure beats using dental instruments. I think the ultras were sprayed w/automotive spray paint and that may be why they were so troublesome.
Automotive sprays tend to be enamels.
These are harder to shift by design.
Acrylics can be lifted with methylated spirits - enamels cannot - they require a more powerful agent.
The fluid that I use has successfully removed paint from plastics AND metals with no damage, even after scrubbing with a firm toothbrush.
None of the "enviro-friendly' cleaners have had anywhere near the same effect so I simply use what works.
I've have been using DOT3 brakefluid for years on any kind of plastic model and it works fine. I never really noticed any weakening within the model itself, maybe if it was the thinner piece such as a spear then this is a possibility. For pewter models it works fine, but takes a little longer.
(Depending on how thick the layers are I leave my models in DOT3 fluid for about 2-3 days.)
A faster way to strip any pewter products is to use acetone. Strip's everything off to the original model with a hours time. ( I usually leave mine in for a couple of hours just in case). This products does not work with resin or plastic!
Oki, so i just cleaned a 3000 point marine army and all my old minis and i assure you that bar none, easy off is best for metals (just give them a real good spray and keep them going for at least 6 - 8 hours) but for plastic dont waste time or money - just use metho.
Thats right METHO has given me the very best results compared to simple green (which is a pain in the ar*e to source in australia) just let it soak for about a day it doesnt degrade the plastic.I did this with blackreach minis regular kits and a landraider so give it a go ( just use a toothbrush to clear it off )
