Night Runner Posted July 23, 2010 Share Posted July 23, 2010 I have stumbled upon these two minis while looking for something to represent a Chooser of the Slain model. Since the Codex states that they often take the form of a Psyber-raven; it means that an eagle could pass for it as well. They are a bit expensive but since you only need one or two, I might think on getting one and cutting off the eagle and sticking it on a stone. It will still be smaller than the Rune Priest methinks. Here are the links: http://www.coolminiornot.com/shop/miniatur...stringer-1.html http://www.coolminiornot.com/shop/miniatur...stringer-2.html So, what do you guys think? Link to comment https://bolterandchainsword.com/topic/207098-chooser-of-the-slain-model/ Share on other sites More sharing options...
Lord Clinto Posted July 23, 2010 Share Posted July 23, 2010 I imagine Choosers could be made from whatever animal the Ironpriest/Runepriest has available at the time. Birds are probably the best for their ability to watch from skys or a high perch. For those minis, I don't see why not, those are fine looking birdies. Maybe add a greenstuff bionic eye or somesuch. Link to comment https://bolterandchainsword.com/topic/207098-chooser-of-the-slain-model/#findComment-2470197 Share on other sites More sharing options...
CainTheHunter Posted July 23, 2010 Share Posted July 23, 2010 Sure, why not? They are very dynamic and You will also get a guy from the second mini who looks like Riddick :mellow: Link to comment https://bolterandchainsword.com/topic/207098-chooser-of-the-slain-model/#findComment-2470290 Share on other sites More sharing options...
Simo429 Posted July 30, 2010 Share Posted July 30, 2010 I was thinking about making a chooser out of the chaos sorcerer games day model, the horns make it look like Loki from Marvel What does everyone think http://cgi.ebay.co.uk/ws/eBayISAPI.dll?VIS...em=230504260030 Link to comment https://bolterandchainsword.com/topic/207098-chooser-of-the-slain-model/#findComment-2476094 Share on other sites More sharing options...
LoneSniperSG Posted July 30, 2010 Share Posted July 30, 2010 While we're on the subject of choosers, if I have one represented as a small bird (clipped off the Fantasy Empire general) on a 25mm base, or a servo-skull on a 25mm base, are these smaller than the Rune Priest model like they're supposed to be? Link to comment https://bolterandchainsword.com/topic/207098-chooser-of-the-slain-model/#findComment-2476125 Share on other sites More sharing options...
pryor Posted July 30, 2010 Share Posted July 30, 2010 I'm going to use one of the servo skulls from the devastator box on a small flying base. My only question is that the book says that the Chooser of the Slain is represented by a model smaller than the Rune Priest. That mean smaller in height, right? Link to comment https://bolterandchainsword.com/topic/207098-chooser-of-the-slain-model/#findComment-2476219 Share on other sites More sharing options...
jmurph Posted July 30, 2010 Share Posted July 30, 2010 Smaller isn't entirely clear. It seems they don't want a PA model as the Chooser. On thing to consider is that the smaller the model, the harder to trace LOS and so the less effective it is. I use the servo skull from the dev box. Looks good painted up, is smaller and makes sense. Link to comment https://bolterandchainsword.com/topic/207098-chooser-of-the-slain-model/#findComment-2476553 Share on other sites More sharing options...
Fred Johnson the 3rd jr Posted July 30, 2010 Share Posted July 30, 2010 My only question is that the book says that the Chooser of the Slain is represented by a model smaller than the Rune Priest.That mean smaller in height, right? It can actually be the same size or smaller. Probably means the same size or smaller in each dimension. Link to comment https://bolterandchainsword.com/topic/207098-chooser-of-the-slain-model/#findComment-2476554 Share on other sites More sharing options...
Beef Posted July 30, 2010 Share Posted July 30, 2010 I use a wolf or failing that I have some dogs from the mordenheim witch hunter range, small rotwielers Link to comment https://bolterandchainsword.com/topic/207098-chooser-of-the-slain-model/#findComment-2476583 Share on other sites More sharing options...
