Odsox Posted July 24, 2010 Share Posted July 24, 2010 Okay, sorry if this is a bit vague, but I've got the desperate urge to make a Chapter Master after hearing so many recommendations during the tournament the other week and I need some advice and suggestions with the modelling side of things. I've already decided that I want to build two variants; a Counts-As Kantor and a Counts-as Lysander. I'm going to do Lysander first. The rules state that the old Space Lemon uses a Thunder Hammer and Stormshield, and I want a knightly look to the most important Space Marine of the Chapter, so I want to modify a Grey Knight Terminator. Specifically this one. I'm gonna nab a Thunder Hammer and doll it up a bit, and a shiny storm shield, preferably a big one, to mount on the left arm. Removing the storm bolter shouldn't be a problem. I'll try and keep a log if I can, but I'd appreciate any advice or suggestions on this! Cheers guys, Od. Link to comment https://bolterandchainsword.com/topic/207164-diy-chapter-master-question/ Share on other sites More sharing options...
chenley Posted July 24, 2010 Share Posted July 24, 2010 Sounds great, would love to see wips. But you know that the plastic terminator arms will fit on the grey knight terminators, and vice versa? It's easier to kit bash and mix arms, then hack and slash. Link to comment https://bolterandchainsword.com/topic/207164-diy-chapter-master-question/#findComment-2471144 Share on other sites More sharing options...
Odsox Posted July 25, 2010 Author Share Posted July 25, 2010 But you know that the plastic terminator arms will fit on the grey knight terminators, and vice versa? This I did not know. Thanks for the tip, I shall keep that in mind! Link to comment https://bolterandchainsword.com/topic/207164-diy-chapter-master-question/#findComment-2471614 Share on other sites More sharing options...
