Captain Conrad Posted July 26, 2010 Share Posted July 26, 2010 I've been looking at the epic range but cant quite understand how many of each type you get and how many in a stand with the space marine battle company, could anyone inform me? Also what models are in the command set? thanks in advance. Link to comment https://bolterandchainsword.com/topic/207315-some-questions-about-epic/ Share on other sites More sharing options...
Vaaish Posted July 26, 2010 Share Posted July 26, 2010 With the strip base you get 5 slots for models. The numbers sounds a bit odd based on the description, though. You used to have enough models to make 2x tactical detachments, 2x devastator detachments, and 2x assault detachments. I'll have to check when I get home, but I believe there is one sprue with a variety of marine captains in power armor and terminator armor, a sprue of librarians with the same, one of chaplains and a bike with a libby and one with a chaplain. Link to comment https://bolterandchainsword.com/topic/207315-some-questions-about-epic/#findComment-2472845 Share on other sites More sharing options...
Angel_of_Caliban Posted July 27, 2010 Share Posted July 27, 2010 Hi, Epic is Awesome! I'll try to help answer questions like my good associate Vaaish In the Space Marine Battle Company Box Set you get 2 full formations of Assault Marines (8 Stands Total) and your choice of 3 Devastator OR Tactical Formations plus some extra basic marines to make Character stands. This all assuming you plan on putting 2 Heavy Weapon marines and 3 basic marines on a Dev stand and 1 Heavy Weapon marine and 4 basic marine on each Tactical stand. They only give you 16 Heavy Weapon marines and 96? Basic and of course the 40 Assault. The reason I have this odd random knowledge and numbers is I just help my friend put together his SM box after I talked him into Epic. If you plan on doing Air Assault Force I would recommend 2 Assault, 2 Devastator and 1 Tactical detachments. A found tactic and sound one is putting a Assault and Devastator formations in a Thunderhawk and doing Ground Assault. if you take your 4 formations like this it leaves your Tactical formation to Garrison. As for the Space Marine Character Pack you get : 1 Spure of Jump Pack Leaders (1 Chaplin, 1 Liberian, 2 Commanders?) 1 Spure of Bike Leaders (1 Chaplin, 1 Liberian, 2 Commanders?) 1 Spure of Terminator Leaders (1 Chaplin, 1 Liberian, 2 Commanders?) 2 Spure of Power Armour Leaders (1 Chaplin, 1 Liberian, 2 Commanders?) 1 Spure of Facny Stuff (Supreme Commander, Standard Bearer, Techmarine? and few more?) EDIT:On hindsight vaaish may be right that there spured by Character type instead of Amour type. But the numbers should be the same. I would say 99% of SM players use only Chaplains in there Assault Formations and Liberians in there Devastators. With Tactical I would say its a mix bag with the Commander being more common. Terminators I would say mix bag again with a preference to Chaplain. I'm not sure on Bikes however I would most like use Commander or Chaplain there. Building Formations your kinda force to pick with the Assault Formations unless you plan on buying an extra box just to have different Character options. But with the marines you might do what my friend did. Now I don't really like it but he wanted flexibility on a budget. He took all the extra basic marines and just put for on a stand with a character. His plan is to use them as replacements for either Tactical or Devastators formations, giving him the ability to run his 2 Dev's or 1 Tactical pure or with a mix bag of added characters. If your starting from scratch I would recommend buying the following as a good core. 1 or 2 Boxes of SM 1 Character Pack 1 Hunters Pack 2 Thunderhawks Then maybe 1 Terminator Pack 1 or 2 Warhound Titans 1 Speeder or Bike Pack 1 Whirlwind Pack 1 Thunderbolt Pack Hope this help. You can download the rules free by the way on the GW website. 3000 points in the standard Tournament size army. Link to comment https://bolterandchainsword.com/topic/207315-some-questions-about-epic/#findComment-2473447 Share on other sites More sharing options...
Octavulg Posted July 27, 2010 Share Posted July 27, 2010 Just a point, here. A Devastator formation will use 8 Heavy Weapons and 12 normal marines. For Tacticals, there's less of a convention. I go with one heavy weapon every other base, which pretty much reproduces a tactical squad (a formation being three tactical squads). Another option is to do what some people do - use no heavy weapons in your tactical formations. Then you can make two Devastator formations and two Tactical formations, with a bunch of marines left over for character bases. A Tactical formation will thus use between 0 and 6 Heavy Weapons and 30 and 24 normal Marines. Another alternative is to buy two battle companies and just make four tactical formations, two devastators and two assaults, thus giving you two battle companies. The trick is figuring out what do with the extra assault marines... Link to comment https://bolterandchainsword.com/topic/207315-some-questions-about-epic/#findComment-2473481 Share on other sites More sharing options...
Captain Conrad Posted July 27, 2010 Author Share Posted July 27, 2010 Right, okay, would you be able to give me a common list you use to show me a how the balance of units works? Thanks for all the help. Link to comment https://bolterandchainsword.com/topic/207315-some-questions-about-epic/#findComment-2473514 Share on other sites More sharing options...
Octavulg Posted July 27, 2010 Share Posted July 27, 2010 The basic tournament list involves one or two Thunderhawks (with contents for same) and two Warhounds. Things vary a bit after that. Keep in mind, though, that there are a variety of alternate lists available for Marines (as well as other races). The basic Codex Astartes Space Marine list is generally accepted to be primarily focused around Air Assaulting (opinion differs over whether or not it should be). Epic UK is the main tournament and Epic organization in the UK. They keep lists of tournament results - including many of the lists that are used. Click on the name of a tournament participant to see his list. NetEA is the other major epic organization. They produce a variety of lists as well (generally, I prefer their lists, since they seem to be a little more willing to change than EpicUK). The top three Codex lists at the last few Epic tourneys are as follows: Richard Laking - Open War 13 Codex Marines Tactical + Sup Cmdr + Hunter Land speeders Devastartors + Hunter Terminators + Chaplain Thunderhawk Terminators + Chaplain Scouts Scouts Titan/Air Third Warhound Warhound Thunderbolts David Thomas - Full Scale Assault 2010 Codex Marines Tactical Formation + Supreme Comm. + Hunter (BTS) Tactical Formation + Hunter Tactical Formation Thunderhawk Thunderhawk Terminator Formation + Librarian Scout Formation Land Speeder Formation Titan/Air Third Warhound Warhound Thunderbolt Formation Ben Skinner at another tournament whose name I missed Tactical + Sup Cmdr + Hunter Tactical Terminators + Chaplain Assault + Chaplain Assault + Chaplain Assault Devastator + Librarian Thunderhawk Titan/Air Third Thunderbolts Warhound Warhound We can notice a few things from this. First, that while there is some variation in tournament lists, there are also some serious points of commonality. Second, that a lot of the most popular Space Marine toys aren't the ones that would be most common in the game (if this bothers you, there are a variety of NetEA lists which try to address this in a variety of ways). Looking at the above, a decent starter list might be: Terminators + Chaplain - 400 Tactical + Supreme Commander + Hunter + Razorback - 500 Tactical - 300 Thunderhawk - 200 (or a Land Speeder Detachment with Tornado for 225) Devastator + Librarian - 300 Assault - 175 Thunderhawk - 200 Land Speeders with Tornado - 225 Thunderbolts - 150 Warhound - 275 Warhound - 275 =3000 This list would require a Battle Company box, a pack of Terminators, a pack of Hunters, a pack of Rhinos, a pack of Razorbacks, two Thunderhawks, the Command pack (though you could also just paint normal marines in specialist colors), a pack of Land Speeders, a pack of Thunderbolts, and two Warhounds. OR (if you're somewhat less concerned about being fluffy) Tactical + Supreme Commander + Hunter +Razorback - 475 Assault - 175 Devastator with Librarian - 300 Thunderhawk - 200 Assault - 175 Devastator - 250 Thunderhawk - 200 Terminator +Chaplain - 400 Thunderbolts - 150 Warhound - 275 Warhound - 275 =3000 This list would require a Battle Company box, a pack of Terminators, a pack of Rhinos, a pack of Razorbacks, two Thunderhawks, the Command pack (though you could also just paint normal marines in specialist colors), a pack of Thunderbolts, and two Warhounds. I`m not sure it`s the greatest list in the world, but it should be OK. Depending on where you live, there are a variety of online stores which might be a good idea to purchase from. Discounts are helpful with Epic. EDITED SO THE POINT COSTS ACTUALLY WORK. Link to comment https://bolterandchainsword.com/topic/207315-some-questions-about-epic/#findComment-2473534 Share on other sites More sharing options...
Captain Conrad Posted July 27, 2010 Author Share Posted July 27, 2010 Ok thanks for all the help, i think i've got a idea now. Link to comment https://bolterandchainsword.com/topic/207315-some-questions-about-epic/#findComment-2473669 Share on other sites More sharing options...
Octavulg Posted July 27, 2010 Share Posted July 27, 2010 Actually, I misremembered the prices on assault marines. It's 175, not 150. Oops. Link to comment https://bolterandchainsword.com/topic/207315-some-questions-about-epic/#findComment-2473794 Share on other sites More sharing options...
Vaaish Posted July 27, 2010 Share Posted July 27, 2010 Two things Octavulg: The speeder formation would work better with a typhoon since it gives it much greater range to put a BM on a target to prep it for assault from a thunderhawk. You can also buy a pack of two epic scale warhounds from forgeworld again which gives you the nicer Lucius pattern versions to match the warlord. Link to comment https://bolterandchainsword.com/topic/207315-some-questions-about-epic/#findComment-2473805 Share on other sites More sharing options...
Angel_of_Caliban Posted July 27, 2010 Share Posted July 27, 2010 . You can also buy a pack of two epic scale warhounds from forgeworld again which gives you the nicer Lucius pattern versions to match the warlord. Indeed Plus the price difference is ridiculous. $25.00 for 1 GW Warhound or $35.00 for 2 FW Warhounds. Right there swings my vote but to make it a better than FW ones look awesome and the GW look like poop. The lists and info that Octavulg looks sound. Notice our buy list is very similar if not the same. B) Link to comment https://bolterandchainsword.com/topic/207315-some-questions-about-epic/#findComment-2473994 Share on other sites More sharing options...
Octavulg Posted July 27, 2010 Share Posted July 27, 2010 The speeder formation would work better with a typhoon since it gives it much greater range to put a BM on a target to prep it for assault from a thunderhawk. I meant Typhoon. I just couldn't remember which was which. Please don't take my Space Marine license away. :P * * * Both AoC and Vaaish are completely right. B) And the lists I originally posted had bad, bad math errors. They've been corrected/revised. No particularly big changes. Link to comment https://bolterandchainsword.com/topic/207315-some-questions-about-epic/#findComment-2474015 Share on other sites More sharing options...
