ZONKEY Posted July 26, 2010 Share Posted July 26, 2010 Allocating wounds with wolves as wargear do the normal rules apply ??? Link to comment https://bolterandchainsword.com/topic/207328-allocating-wounds-with-wolves-as-wargear/ Share on other sites More sharing options...
Grimtooth Posted July 26, 2010 Share Posted July 26, 2010 Depends on whether the wounds are from shooting or close combat. Shooting, the wounds are allocated to the unit. Close combat, the IC is his own unit so attacks would have had to been allocated to him specifically. Would even be different for an Iron Priest with cyber wolves because he isn't an IC. Link to comment https://bolterandchainsword.com/topic/207328-allocating-wounds-with-wolves-as-wargear/#findComment-2472960 Share on other sites More sharing options...
Stormbrow II Posted July 26, 2010 Share Posted July 26, 2010 You mean when a Character or Lone Wolf buys 1 or 2 of them as upgrades? Yeah, you can allocate wounds onto them from shooting and then make saves if you get one e.g. LW with 2 Wolves take 8 Bolter wounds and 1 Melta wound. You put 3 Bolter wounds on one wolf, 2 Bolter and 1 Melta on the other wolf and 3 Bolter wounds on the Lone Wolf. In combat you must allocate attacks to the Wolves seperately. Link to comment https://bolterandchainsword.com/topic/207328-allocating-wounds-with-wolves-as-wargear/#findComment-2472961 Share on other sites More sharing options...
Grimtooth Posted July 26, 2010 Share Posted July 26, 2010 In combat you must allocate attacks to the Wolves seperately. Only for IC Stormbrow. The LW is not an IC so is not a separate unit in close combat. Close combat attacks are allocated to the unit and wounds are allocated to the unit. Link to comment https://bolterandchainsword.com/topic/207328-allocating-wounds-with-wolves-as-wargear/#findComment-2472963 Share on other sites More sharing options...
Guganation Posted July 26, 2010 Share Posted July 26, 2010 Depends on whether the wounds are from shooting or close combat. Shooting, the wounds are allocated to the unit. Close combat, the IC is his own unit so attacks would have had to been allocated to him specifically. Would even be different for an Iron Priest with cyber wolves because he isn't an IC. I was trying to figure this out the other day. So. You're saying that an IC with 2 wolves is concidered "his own unit". Doesn't that then mean that when you give an IC wolves as wargearHe can't then join a larger unit? Becuase then it would be a unit joining a unit. If this is explained somewhere I haven't been able to find it. Link to comment https://bolterandchainsword.com/topic/207328-allocating-wounds-with-wolves-as-wargear/#findComment-2473023 Share on other sites More sharing options...
Stormbrow II Posted July 26, 2010 Share Posted July 26, 2010 @Brother Ramses: Good man for spotting that. I was gone back to thinking about the IC's wolves and forgot to add that to the sentence. @Guganation: He keeps the IC rule and doesn't get a retinue as per the FAQ - shooting will be resolved as in my previous example but in combat you allocate attacks to either the Wolves or the Character. I.e. an IC with 2 Wolves in a unit of Grey Hunters charges into combat with a Trygon. As the Trygon is in base contact with the IC, the Wolves and the Grey Hunters it can choose who to allocate its attacks towards. Link to comment https://bolterandchainsword.com/topic/207328-allocating-wounds-with-wolves-as-wargear/#findComment-2473032 Share on other sites More sharing options...
Guganation Posted August 1, 2010 Share Posted August 1, 2010 @Brother Ramses: Good man for spotting that. I was gone back to thinking about the IC's wolves and forgot to add that to the sentence. @Guganation: He keeps the IC rule and doesn't get a retinue as per the FAQ - shooting will be resolved as in my previous example but in combat you allocate attacks to either the Wolves or the Character. I.e. an IC with 2 Wolves in a unit of Grey Hunters charges into combat with a Trygon. As the Trygon is in base contact with the IC, the Wolves and the Grey Hunters it can choose who to allocate its attacks towards. Awesome. thanks, Stormbrow. I now get to explain to my game group :cuss Link to comment https://bolterandchainsword.com/topic/207328-allocating-wounds-with-wolves-as-wargear/#findComment-2477645 Share on other sites More sharing options...
