ChrisSpaceWolves Posted July 27, 2010 Share Posted July 27, 2010 First attempt at any real free hand http://i332.photobucket.com/albums/m339/ChrisMBianchi/100_6404.jpg More to come Link to comment Share on other sites More sharing options...
Ufthak Posted July 27, 2010 Share Posted July 27, 2010 Hm, generally the hand is quite good, but I would recommend leaving thin yellow lines instead of the grey that you used; that way it stands out more. Apart from that: the yellow of the Rhino looks more brown than anything, like Bleached Bone covered in Devlan Mud. If you're truly doing Imperial Fists then I recommend Iyanden Darksun or even Sunburst yellow. Link to comment Share on other sites More sharing options...
ChrisSpaceWolves Posted July 27, 2010 Author Share Posted July 27, 2010 Hm, generally the hand is quite good, but I would recommend leaving thin yellow lines instead of the grey that you used; that way it stands out more. Apart from that: the yellow of the Rhino looks more brown than anything, like Bleached Bone covered in Devlan Mud. If you're truly doing Imperial Fists then I recommend Iyanden Darksun or even Sunburst yellow. the yellow doesnt look right because of the lighting in the picture. Check my other post recently for the actual color of the tank. Its identical to my Chapter Master. The thumb didnt come out right but hey we gotta start somewhere ;) Thanks for the CC Link to comment Share on other sites More sharing options...
