Initiate of the Templar Posted July 30, 2010 Share Posted July 30, 2010 Hail Brothers After replaying DoW: Winter Assault I thought it would be awesome to make a table with the Hellstorm Cannon as the centerpiece, complete with gigantic canyon carved out of its firing path. I decided to use Pink insulation foam for the basic hill shape but I'm having trouble deciding what to build the Cannon out of, any thoughts? Keep in mind Im on a limited budget but I still want it to look like an approximation of the actual ingame visual. Link to comment https://bolterandchainsword.com/topic/207614-how-to-model-a-hellstorm-cannon-from-dow-winter-assault/ Share on other sites More sharing options...
The Normish Posted August 1, 2010 Share Posted August 1, 2010 I think I know what you mean. Well, although I have zero experience building scenery, maybe some plastic tubes or cardboard ones would work. The canyon would have to be foam, or something similar, like you suggested. Link to comment https://bolterandchainsword.com/topic/207614-how-to-model-a-hellstorm-cannon-from-dow-winter-assault/#findComment-2477804 Share on other sites More sharing options...
Brother Valerius Posted August 2, 2010 Share Posted August 2, 2010 Maybe ask in PC&A, where those who are artistically inclined (and might not see this thread) can offer advice? Link to comment https://bolterandchainsword.com/topic/207614-how-to-model-a-hellstorm-cannon-from-dow-winter-assault/#findComment-2478362 Share on other sites More sharing options...
Hemal Posted August 2, 2010 Share Posted August 2, 2010 Indeed - PC&A would be able to provide much guidance. Essentially, the Hellstorm is a titan weapon, principal armament of an Imperator class Emperor titan. It would be about twice as long as the gatling blasters on a Reaver titan - so find a forgeworld model or template you can use to scale from. Diameter of each barrel is (I think...based loosley on my epic scaled model) about 2* the height of a marine, so probably a similar height scaled up to 40K would work (60 mm diameter tubing would be good..). About modelling it, I would build up a skeleton of poly foam, cut lossley into teh shape of a canyon, and put the model in there. Cover the foam in white glue, and then you can use the spray on filler to create teh surrounding rock faces etc - but as stated above - teh PC&A has FAR better modellers than I available to do this... Link to comment https://bolterandchainsword.com/topic/207614-how-to-model-a-hellstorm-cannon-from-dow-winter-assault/#findComment-2478732 Share on other sites More sharing options...
iixHAZZAxii Posted August 7, 2010 Share Posted August 7, 2010 Sorry to go a bit off topic, but Hemal and Brother Valerius, where did you get your Avatars? Link to comment https://bolterandchainsword.com/topic/207614-how-to-model-a-hellstorm-cannon-from-dow-winter-assault/#findComment-2483185 Share on other sites More sharing options...
Brother Valerius Posted August 7, 2010 Share Posted August 7, 2010 There's a gallery of pre-made avatars in the control panel. Link to comment https://bolterandchainsword.com/topic/207614-how-to-model-a-hellstorm-cannon-from-dow-winter-assault/#findComment-2483255 Share on other sites More sharing options...
raptor1199 Posted August 13, 2010 Share Posted August 13, 2010 wasnt the cannon in dark crusade not in WA? Link to comment https://bolterandchainsword.com/topic/207614-how-to-model-a-hellstorm-cannon-from-dow-winter-assault/#findComment-2488114 Share on other sites More sharing options...
