Devastator Squads
Rhodric
I've been using a 5-man Dev. Squad equipped with Missile Launchers in my last few games. I've been very happy with the results so far. One thing that just came to mind was the blast template of the Frag Missile. For some reason I'm drawing a blank on this. I've been declaring my target, placing template etc for each Dev on the "same" model. I want to make sure I'm not doing something wrong here. When firing at a unit, 10 Dire Avengers for example, can the pie plates be distributed to more than one model or must they all hit the same target? I'm assuming the same target, but am not positive now.
Thanks!
https://bolterandchainsword.com/topic/207883-devastator-squads/
I'm pretty sure as long as you have LOS to the model of a unit you can put the template over it. So any model of a unit it the missile guy has true LOS to is fair game. Pretty sure.
I really like my devs too btw, really surprisingly effective, and pretty points efficient.
So, if there are 10 models in a unit, the templates can be placed on four different models for maximum coverage if "all" models firing have LoS? If so, I've been doing things way wrong haha! And the killing power of my Dev. Squad just went through the roof!
Yes. There is nothing that I can see in the rules that says they all have to be on the same target and common sense tells you that you would aim for maximum spread.
See, this is what I thought, but my friend convinced me other wise lol. We're both a bit rusty :P.
Not to be rude, but surely it makes sense for the whole unit to target the one model where the template hits the max # of bases? Wound allocation still occurs, so if putting the template on one Ork hits a total of 5, and all the others you can target would hit 4 or less, why would you aim at different targets? Am I the one missing something?
GlauG is right (or I'm failing to understand the original question). You could technicall yplace the template on any squad member but if you place it over the model that yields the most hits then why would you try for a different model in that squad?
I've been using Dev's for a few weeks now in my Jump Pack army and I have to say I'm really enjoying them. In a game vs Nids last week they single-handedly killed 20ish Termagaunts, 2 Zoanthropes, and a Hive Guard, they definitely paid for their 130 point cost.
What I'm saying is that I've been stacking all four Frag Missile templates on the same model, hitting the same 5 models (for example). What I wasn't clear on was if I could spread those four templates over the entire unit, this hitting more models. I get the idea of max coverage, but am just fuzy on if you can place the templates where you'd like, i.e. more than one model.
And you're not being rude at all. I may not be explaining this properly.
You dont have to put the templates over the same model, but If there's 1 place that gets you 5 hits and naother that only gets you 4 hits then you're better served aiming for the 5. Dont forget that the wounds you cause have to be applied to the entire squad, not just the 5 guys under the template - there really is no need to spread the templates out.
Imagine - 10 man marine squad, 6 in a conga line and 4 bunched base to base. I fire 4 frag missile at them and hit all 4 times and wound on every hit. That squad must now take 16 saves, spread out over the entire squad, including the guys in the conga-line. Which is a far better chance of killing more marines than 1 frag missile on the 4 bunched marines, and then 3 other frag missiles only hitting 1 guy (maximum 7 wounds caused).
Hope that helps a bit (and I know I've been ridiculous on the hit/wounds but its for illustrative purposes)
We've been doing it wrong then. I was under the impression that only the models under the template took the wounds. This changes a LOT of things! Thank you very much for the explenation!
Also, you don't necessarily have to place the center of the template over the center of the model. As long as the center of the template is over the base of the model you're good. Some people get VERY irate about this in games when I pull it off, but then I show them the picture in the BRB of the blast weapon being placed and usually they can be reasoned with.
sorry for my question
but this is same as 3 teplates for furioso frag cannon and heavy flamer?
i can place 3 abowe same orc mob and wounds goes to all squad?
if so....its so cruel
sorry for my english :)
Yes, that's right. Any wounds you do, be it 1 or 20, are applied to the entire squad (or as many as you have wounds to give out) as per wound allocation rules. Not just those under the template(s).
Yeah I had a hard time with it too... if just 1 ork is visible of a unit of 50 boyz... and you dump 4 heavy bolters, and a full tactical squad rapid firing bolters ... you could up end up with like 20 orks dead...
By the same basis always put your template on the most amount of models you can cover, say you get 5, and you shoot 4 times, and don't scatter. You now have 20 hits (since you dont roll to hit with template weapons)
You have to try and wound now, so its totally possible to kill guys in the same unit that were not under the template.
wow thank you
its make sad my orc friend who is my only opponent
No, I'm sure this is not true. What about LoS? If only 1 Orc is visible, then only 1 Orc can die right?
If only one Ork is visible that the unit would benefit from a cover save 4+, as long as every model firing has line of sight to that one visible Ork
See BRB p21 - 23
