mythicast
amrogers3
I am also unfamiliar with an "undercoat". Mold release usually feels somewhat slick or greasy. It can be removed with warm water and soap or a little rubbing alcohol (it cuts the silicon agent). If your models were actually undercoated, I would try a bath of Simple Green followed by a toothbrush.
https://bolterandchainsword.com/topic/208267-mythicast/#findComment-2485385
Yes mine where undercoated poorly in gray (to cover up some gs work) I removed it using Sint marc
http://www.eco-logisch.nl/tuin/images/stmarc.jpg
Its a dutch product so have no idea what product to use in your country
Simple Green if you are in the US.
http://toolmonger.com/wp-content/uploads/2007/10/1010040285.jpg
Valerian
https://bolterandchainsword.com/topic/208267-mythicast/#findComment-2485415
they do it to hide the repairs they made, Id rather just see the Green stuff, when i order the ironpriest mount i will tel them not to :)
I would test if simple green is safe on a base you got, put it in for a day, id it doesnt melt, its safe ;)
https://bolterandchainsword.com/topic/208267-mythicast/#findComment-2485894
Thanks for the replies. I will try some simple green and see what happens. Not sure why Mythicast would undercoat the miniatures!?
Is Simple Green ok to use on resin?
Simple Green Product Review: Yeah, should be good on Resin. Check the link I just provided to read about Simple Green used to strip paint from metal, plastic, and FW resin models.
Valerian
https://bolterandchainsword.com/topic/208267-mythicast/#findComment-2486857
