tubo10 Posted August 10, 2010 Share Posted August 10, 2010 Hi, im not completly sure if this should go here, but it seemed the best choice. -havnt been on in long time and forgotten where things are, sorry if in wrong place. Im going to be useing a choas sorcerer for a 750pt army for a doubles competion at warhammer world. I brought ahriman and im going to convert him into a normal sorcerer, the rules are that the models must be on base they came with, heres the problem. my arhiman came with a terminator base and a normal base, im not sure if this is normal or mistake in packaging, im also converting him (changing parts of spear/head/backpack) to make sure people can tell he should be sorcerer not arhiman, normal sorceres are on small bases. Do i put him on small base as hes not going to be arhiman and instead be a normal sorcerer? I just keep worrying that because he also came with big base he will need to be on that one, although normal ones arnt I know this may seem like a very very simple question but i would really like some other opinions as i dont want to turn up and they tell me i cant use him for what ever reason. Thank you for any and all help and advice people give. Link to comment Share on other sites More sharing options...
ShinyRhino Posted August 10, 2010 Share Posted August 10, 2010 Put him on the small base and you'll be fine. Standard infantry almost always end up on small 25mm bases. Link to comment Share on other sites More sharing options...
Seahawk Posted August 10, 2010 Share Posted August 10, 2010 As it came with both, you can chose which to base him on. Link to comment Share on other sites More sharing options...
Hellios Posted August 10, 2010 Share Posted August 10, 2010 It came with both so both are fine... personally I don't care for that rule.. I like my HQ models on larger bases so I can make the bases more interesting... and I've found doubles are normally more friendly so I doubt you will have a problem... but if he came with a terminator base then you are all good RAW. Link to comment Share on other sites More sharing options...
Tanhausen Posted August 10, 2010 Share Posted August 10, 2010 Worst case scenario: you use small base, if somebody whines, just bluetack onto the big base :P Link to comment Share on other sites More sharing options...
tubo10 Posted August 10, 2010 Author Share Posted August 10, 2010 Okay, thx alot. just making sure. Link to comment Share on other sites More sharing options...
Grey Mage Posted August 10, 2010 Share Posted August 10, 2010 As it came with both, you can chose which to base him on. Yep- when they give you options, THE POWER IS YOURS. Buahahahaahaa Seriously though- the one on their website is on a TDA base, but both my chaos playing friends have ones from before when it was just the 25mm included *shrugs* Link to comment Share on other sites More sharing options...
