bushman101 Posted August 12, 2010 Share Posted August 12, 2010 I'm painting up a unit of VV, currently without JPs. But the more I think about it, it seems like using JPs is the optimal choice (especially to make use of Heroic Intervention). What do people on the boards here think? Are JPs a must with VV or not? Thanks in advance Link to comment https://bolterandchainsword.com/topic/208448-vanguard-vets-question/ Share on other sites More sharing options...
Deus_Sanguinius Posted August 12, 2010 Share Posted August 12, 2010 From my point of view HI is THE reason why I would play VV. So I definitely recommend JPs for them. Regards Sang Link to comment https://bolterandchainsword.com/topic/208448-vanguard-vets-question/#findComment-2487344 Share on other sites More sharing options...
Drudge Dreadnought Posted August 12, 2010 Share Posted August 12, 2010 If you aren't using heroic intervention, you are going to be better off with honor guard, assault marines, or death company. Link to comment https://bolterandchainsword.com/topic/208448-vanguard-vets-question/#findComment-2487420 Share on other sites More sharing options...
Chimaera2000 Posted August 12, 2010 Share Posted August 12, 2010 I agree that Death Company are generally the better choice if you're not giving the Vanguard Veterans jump packs. There's are niche situations where Vanguard would be useful without jump packs, such as a Land-raider heavy list at very high points-level where the Force Organization chart is becoming a limitation. In 2000 points or less, though, Veterans with jump packs is usually the sensible option. So to answer your question, it's not strictly necessary to give them jump packs, just sensible. Link to comment https://bolterandchainsword.com/topic/208448-vanguard-vets-question/#findComment-2487458 Share on other sites More sharing options...
TrentL Posted August 13, 2010 Share Posted August 13, 2010 Do like I did with my death company. Install magnets so you can switch backpacks get the best of both worlds! Link to comment https://bolterandchainsword.com/topic/208448-vanguard-vets-question/#findComment-2487467 Share on other sites More sharing options...
bloodancient Posted August 13, 2010 Share Posted August 13, 2010 I decided to go either way with them there are 10 with JP's and 10 on foot that come out of a crusader with a priest and smetimes a chappy they just might be my favorite squad. They always make it where i want them and totally defeat the enemy twenty zerks and only got the charge on the first 10. Link to comment https://bolterandchainsword.com/topic/208448-vanguard-vets-question/#findComment-2487470 Share on other sites More sharing options...
BLACK BLŒ FLY Posted August 13, 2010 Share Posted August 13, 2010 Definitely Vanguard should be kitted with jump packs so you can use HI. It's what makes them an asset. As others have mentioned there are other squads you can take without jump packs for the points. 0b :P Link to comment https://bolterandchainsword.com/topic/208448-vanguard-vets-question/#findComment-2487485 Share on other sites More sharing options...
Firedrake28 Posted August 13, 2010 Share Posted August 13, 2010 There's nothing Vanguard can do that Honor Guard can't do better until the Vanguard are given jump packs imo. Honor Guard come with a Priest and have access to proper special weapons (meaning they don't need to rely on the pistol-sized versions of various guns). If you're running Vanguard, be sure to use Heroic Intervention to its maximum by taking jump packs and using Descent of Angels. Link to comment https://bolterandchainsword.com/topic/208448-vanguard-vets-question/#findComment-2487537 Share on other sites More sharing options...
JamesI Posted August 13, 2010 Share Posted August 13, 2010 There's nothing Vanguard can do that Honor Guard can't do better until the Vanguard are given jump packs imo. Honor Guard come with a Priest and have access to proper special weapons (meaning they don't need to rely on the pistol-sized versions of various guns). If you're running Vanguard, be sure to use Heroic Intervention to its maximum by taking jump packs and using Descent of Angels. The only reason I disagree with this is the Vanguard's ability to have larger squads. I used to run a pretty effective 8 man Vanguard with a reclusiarch and a priest just as if they were an old VAS. Real nasty unit (but oh so many points). Link to comment https://bolterandchainsword.com/topic/208448-vanguard-vets-question/#findComment-2487765 Share on other sites More sharing options...
Zealadin Posted August 13, 2010 Share Posted August 13, 2010 There's nothing Vanguard can do that Honor Guard can't do better until the Vanguard are given jump packs imo. Honor Guard come with a Priest and have access to proper special weapons (meaning they don't need to rely on the pistol-sized versions of various guns). If you're running Vanguard, be sure to use Heroic Intervention to its maximum by taking jump packs and using Descent of Angels. The only reason I disagree with this is the Vanguard's ability to have larger squads. I used to run a pretty effective 8 man Vanguard with a reclusiarch and a priest just as if they were an old VAS. Real nasty unit (but oh so many points). This removes your ability to use Heroic Intervention though Link to comment https://bolterandchainsword.com/topic/208448-vanguard-vets-question/#findComment-2487834 Share on other sites More sharing options...
JamesI Posted August 13, 2010 Share Posted August 13, 2010 There's nothing Vanguard can do that Honor Guard can't do better until the Vanguard are given jump packs imo. Honor Guard come with a Priest and have access to proper special weapons (meaning they don't need to rely on the pistol-sized versions of various guns). If you're running Vanguard, be sure to use Heroic Intervention to its maximum by taking jump packs and using Descent of Angels. The only reason I disagree with this is the Vanguard's ability to have larger squads. I used to run a pretty effective 8 man Vanguard with a reclusiarch and a priest just as if they were an old VAS. Real nasty unit (but oh so many points). This removes your ability to use Heroic Intervention though if you want to use HI, you just don't put the ICs in the unit. Some games I want to HI, some I don't and the squad becomes a large Vet squad. All depends on the game. Link to comment https://bolterandchainsword.com/topic/208448-vanguard-vets-question/#findComment-2487846 Share on other sites More sharing options...
bushman101 Posted August 13, 2010 Author Share Posted August 13, 2010 okay, gonna pry off the back-packs and add JPs. Thanks everyone. My intent was to have a unit that was interchangeable with HonorGuard. Both had gold helmets and skulls on the left shoulder pad, so it seemed easy. But HI seems to good to pass up Link to comment https://bolterandchainsword.com/topic/208448-vanguard-vets-question/#findComment-2488102 Share on other sites More sharing options...
TrentL Posted August 13, 2010 Share Posted August 13, 2010 okay, gonna pry off the back-packs and add JPs. Thanks everyone. My intent was to have a unit that was interchangeable with HonorGuard. Both had gold helmets and skulls on the left shoulder pad, so it seemed easy. But HI seems to good to pass up Rare earth Magnets a drill and some crazy glue and you can accomplish just that!! They can be Jump pack Honor guard or VV, or they can be foot slogging HG or VV.... the sky is the limit! Link to comment https://bolterandchainsword.com/topic/208448-vanguard-vets-question/#findComment-2488133 Share on other sites More sharing options...
Drudge Dreadnought Posted August 13, 2010 Share Posted August 13, 2010 the sky is the limit! But only when using jump packs <_< Link to comment https://bolterandchainsword.com/topic/208448-vanguard-vets-question/#findComment-2488200 Share on other sites More sharing options...
TrentL Posted August 14, 2010 Share Posted August 14, 2010 the sky is the limit! But only when using jump packs ;) Not true!! StormRavens can carry normal troops :teehee: Link to comment https://bolterandchainsword.com/topic/208448-vanguard-vets-question/#findComment-2488273 Share on other sites More sharing options...
