Einholt Posted August 17, 2010 Share Posted August 17, 2010 Hello there, reading Barrage rules in the rulebook and while it says barrage is the same as previous editions but instead of a (G) before the profile barrage replaces this. so just checking this means their still guess weapons right? the wording just struck me as very odd and nowhere apart from that does it state clearly they are a guess range weapon (unless I am blind :P ) Link to comment Share on other sites More sharing options...
Hellios Posted August 17, 2010 Share Posted August 17, 2010 Hello there, reading Barrage rules in the rulebook and while it says barrage is the same as previous editions but instead of a (G) before the profile barrage replaces this. so just checking this means their still guess weapons right? the wording just struck me as very odd and nowhere apart from that does it state clearly they are a guess range weapon (unless I am blind :P )Thye are not guess range but if you have an older book that refers to guess range it means barrage :P Link to comment Share on other sites More sharing options...
Legatus Posted August 17, 2010 Share Posted August 17, 2010 No more guessing. You just place the template and it scatters 2d6 minus the firer's BS. With barrage weapons you can pick a target out of LOS, but if you cannot see the target then you do not substract the BS. Link to comment Share on other sites More sharing options...
Frosty the Pyro Posted August 17, 2010 Share Posted August 17, 2010 No more guessing. You just place the template and it scatters 2d6 minus the firer's BS. With barrage weapons you can pick a target out of LOS, but if you cannot see the target then you do not substract the BS. Aditionaly barrage weapons force pinning tests (with -1 ld if I recal correctly), determine cover from the center of the template, and use multiple barrage rules if there are more than one barrage weapon being fired from a single unit. Link to comment Share on other sites More sharing options...
stinkenheim Posted August 17, 2010 Share Posted August 17, 2010 ordnance barrage force the unit to take a pinning test at -1 leadership. afaik normal barrage simply force a pinning test. Link to comment Share on other sites More sharing options...
