Grand Master Neo Posted August 24, 2010 Share Posted August 24, 2010 what does everybody feel would be the best transport for the deathwing? Link to comment https://bolterandchainsword.com/topic/209218-deathwing-transport/ Share on other sites More sharing options...
chaplain mortis Posted August 24, 2010 Share Posted August 24, 2010 is that games terms or fiction?? land raiders all the way :( Link to comment https://bolterandchainsword.com/topic/209218-deathwing-transport/#findComment-2496123 Share on other sites More sharing options...
Grand Master Neo Posted August 24, 2010 Author Share Posted August 24, 2010 sorry. i should have been more specific what variant of land raider do you think best suits the situation of transporting deathwing Link to comment https://bolterandchainsword.com/topic/209218-deathwing-transport/#findComment-2496137 Share on other sites More sharing options...
Brother-Redemptor Posted August 24, 2010 Share Posted August 24, 2010 Land Raider Crusader allows the Deathwing to assualt into cover without going to initiative 1. Granted it doesn't have the AV14 weapons as the normal land raider, but it still has the MMelta. It works out well for me. I was able to take a 5 man thunderwolf cav, with two lords out with the heavy volume of fire from the LRC and an assualt from 1xStrmBltr/pwrswd, 2x LC, 1xThndrhmr/SS, and a heavy flamer/pwrfist. It just matters at how you use it. Link to comment https://bolterandchainsword.com/topic/209218-deathwing-transport/#findComment-2496145 Share on other sites More sharing options...
Grand Master Neo Posted August 24, 2010 Author Share Posted August 24, 2010 Land Raider Crusader allows the Deathwing to assualt into cover without going to initiative 1. Granted it doesn't have the AV14 weapons as the normal land raider, but it still has the MMelta. It works out well for me. I was able to take a 5 man thunderwolf cav, with two lords out with the heavy volume of fire from the LRC and an assualt from 1xStrmBltr/pwrswd, 2x LC, 1xThndrhmr/SS, and a heavy flamer/pwrfist. It just matters at how you use it. quite freakishly that is the exact same setup i use. would you say then that the lrc is a better choice for deathwing and leave the standard lr to other transport/weapon platforms? Link to comment https://bolterandchainsword.com/topic/209218-deathwing-transport/#findComment-2496167 Share on other sites More sharing options...
pueriexdeus Posted August 25, 2010 Share Posted August 25, 2010 I use the LRC for my CC specific DW, add a Chappi, and/or Libbie and you have icing on the cake. My God Hammers also carry CC TDA. Basic load is TH/SS, 3x LC's, HF/CF Link to comment https://bolterandchainsword.com/topic/209218-deathwing-transport/#findComment-2496374 Share on other sites More sharing options...
Brother-Redemptor Posted August 25, 2010 Share Posted August 25, 2010 I also use the LRC with beliel, Int Cappie w/combi-melta, 2 LC(one has a cyclone), 2 TH/SS, Sarge, carring the company banner. This works out well, because it give a slight ability to be shooty when needed to soften up for the assualt. Also when assualting it a allows for re-rolls all hits with the cappie and gives an extra attack with the banner. So in CC you are looking at 32 attacks from this unit. Thats why i like it Link to comment https://bolterandchainsword.com/topic/209218-deathwing-transport/#findComment-2496833 Share on other sites More sharing options...
Brother-Redemptor Posted August 25, 2010 Share Posted August 25, 2010 quite freakishly that is the exact same setup i use. would you say then that the lrc is a better choice for deathwing and leave the standard lr to other transport/weapon platforms? I still use the standard LR for AV14 but its hard to use in games less then 2000 points Link to comment https://bolterandchainsword.com/topic/209218-deathwing-transport/#findComment-2496835 Share on other sites More sharing options...
RayJ Posted August 25, 2010 Share Posted August 25, 2010 In my opinion it completely depends on the role of the Deathwing squad in question. In my 2000 point Triple Land Raider list, I run 2 land Raiders and 1 Crusader. The Deathwing squads riding in the Land Raiders are equipped with Cyclones to match the range of their transport. Their job is to hold objectives on my side of the table. Belial and his command squad run forward in the Crusader, usually with an assault cannon in the squad, though sometimes I use the Heavy Flamer. They get supported by Dreadnoughts and thinks pretty much play themselves out from there. Against modern marine armies, things can get dicey very fast, with all the lascannon spam on razorbacks in MSU and storm shields in the occasional rock army. Against those opponents, I will typically pull a draw. Mech Guard are the worst matchup, as they have enough firepower and bodies to completely overwhelm the elite force. Proper use of terrain and playing like a brillaint general will net you a draw about 45% of the time there. Against Xenos, I tend to eek out the wins through the basic durability of the land raider. They have it about as rough as we do vs the modern armies. Tyranids are probably the best matchup for this list. A properly built Tyranid list will bring very few zoanthropes, and will use tyrannofexes for fire support. The mech deathwing can hit them very hard both in range and close combat, and the proper use of smoke and terrain will make the fight pretty easy. So the real question is, what role are the Deathwing performing, and how does the rest of your list stack up? There should always be more than one angle to consider when choosing an option for your army. Link to comment https://bolterandchainsword.com/topic/209218-deathwing-transport/#findComment-2496873 Share on other sites More sharing options...
VAGABOND Posted August 26, 2010 Share Posted August 26, 2010 I tend to use LRC for transporting my Deathwing into battle, I usually have 2 Crusaders in 1500 points so I have plenty of mobility. Link to comment https://bolterandchainsword.com/topic/209218-deathwing-transport/#findComment-2497993 Share on other sites More sharing options...
DAG42 Posted August 26, 2010 Share Posted August 26, 2010 Crusader for assault termies for sure. Bigger games I'll put in my Godhammer and Prometheus. Link to comment https://bolterandchainsword.com/topic/209218-deathwing-transport/#findComment-2498043 Share on other sites More sharing options...
