Raven Guard Shadow Captain Lanius
That is one sweet looking model! The darkness of the base really adds to the model itself.
Glad you like it! Do you reckon the base needs something more though? I normally add some kind of static grass for foliage.. but I think in this situation that it might be a bit bright. I did toy with the idea of adding maybe some dead twigs, as burnt branches or something. What do you think? I also need to get hold of some gold paint to do the blade justice.
You can always flock then ink/drybrush it to give it the color you want. It's a kind of finicky thing to do, but it looks good.
Personally I think the base is great as is. Maybe highlight the larger rocks a bit, but then call it done for sure.
Maybe add some moss or similar to the side and edges of the rocks that face the light (the side which you've highlighted from). Don't need much moss, but it will just break up the black of the base a little.
Other than that small suggestion, I really wouldn't change it. It looks great how it is now.
