Madcap Posted August 31, 2010 Share Posted August 31, 2010 I tried searching for this, but I did not see anything that answers my questions. The primary question: I am going to start building two heralds of Tzeentch on chariots. I am debating what figure to use as a herald of Tzeentch. So I was wondering what do others use? I've seen horrors, fantasy champs/sorcerers of Tzeentch, flamers, and all sorts of things. I am interested in what the good folks of this forum use. Right now, I am debating between a horror, a converted Chaos Warrior, or a converted Chaos Sorcerer. The question, by extension, becomes, "What do folks use for other heralds?" There are bits in the plastic kits that make champions, but they don't seem to stand out enough. Khorne and Slaanesh can use Skulltaker and the Masque. Mainly, I am just curious as to what others use. Link to comment https://bolterandchainsword.com/topic/209660-daemonic-heralds/ Share on other sites More sharing options...
lfhoule Posted August 31, 2010 Share Posted August 31, 2010 Well, for my pair of foot-trodding Tzeentch Heralds in my Tzeentch/Slaanesh demon army, I used the bodies of 3rd edition daemonettes that I did not have the arms for anymore, then fashioned crude flamer style arms with green stuff and a cut up paper clip, then during the painting process free handing Tzeentch marks on their behinds (;)). The results look fairly good, considering it was first time using green stuff for more than filling gaps/filling in slotta bases/making roundish rocks. Am looking at using the same process on the several other armless 'nettes I have about to make a unit of "horrors" out of them to continue the theme I have for my army. Link to comment https://bolterandchainsword.com/topic/209660-daemonic-heralds/#findComment-2501517 Share on other sites More sharing options...
Kevlin Posted December 7, 2010 Share Posted December 7, 2010 For Tzeench I use a really old chaos sorcerer that has been stuck with me for almost 15 years but I have found that there are several great models in the Fantasy battle range at GW. They even have a Tzeench sorcerer on disc so you might want to check that out. http://www.games-workshop.com/gws/catalog/...dId=prod1050015 If the link is broken try searching on the site for Lord of Tzeench and you find it. Might have to log in for that since its in the collector range. Alot of great models for Heralds there. /K Link to comment https://bolterandchainsword.com/topic/209660-daemonic-heralds/#findComment-2583426 Share on other sites More sharing options...
Lord Cuthbert Posted February 15, 2011 Share Posted February 15, 2011 Great thing is that all of the ideas you suggested work fine. I use a Horror Champion (heavily converted) for a Tzeentch Herald and oput him on a converted Screamer (showing the transformation into a disk), a Chaos Champion of Nurgle for a Nurgle Herald, a Bloodletter Champion for my Herald of Nurgle, etc... You get the point, I do though take the time to add to the base model since these are obviously the chosen of their respective Gods and should stand out against other of their ilk. Use what you got and be creative, that is the best part about playing a Daemon army! Link to comment https://bolterandchainsword.com/topic/209660-daemonic-heralds/#findComment-2659787 Share on other sites More sharing options...
Mr Peon Posted April 20, 2011 Share Posted April 20, 2011 I was looking at adding some of these to an inverted large flying base that had green stuff flames on it. Painted up in Tzeentch colours i think they will look good, and are not that expensive. http://www.games-workshop.com/gws/catalog/...dId=prod1050068 Link to comment https://bolterandchainsword.com/topic/209660-daemonic-heralds/#findComment-2730551 Share on other sites More sharing options...
Larkyn Posted April 21, 2011 Share Posted April 21, 2011 One of my friends glued a bunch of plastic horrors onto a Chariot base, modeled them to look like they were flying, and then glued the WHFB tzeentch champion that was on the disc onto the backs of some of the horrors. It looks pretty cool, actually. Link to comment https://bolterandchainsword.com/topic/209660-daemonic-heralds/#findComment-2732391 Share on other sites More sharing options...
Vet.Eter Posted April 25, 2011 Share Posted April 25, 2011 For the Khorne Herald I used one jugger and a letter from the juggernauts plastic box and made the chariot for him. With the Tzeentch Heralds I used the plastic horrors, made the discs for them and I'll by some screamers to pull the discs. Link to comment https://bolterandchainsword.com/topic/209660-daemonic-heralds/#findComment-2736609 Share on other sites More sharing options...
Khorne Inquisitor Posted May 24, 2011 Share Posted May 24, 2011 I use chaos sorcerer with fly head for my nurgle herald, either a heavily converted horror or the old three headed WHFB tzeentch champion for tzeentch, and for slaanesh and khorne I use converted chamions of the troops choice. Link to comment https://bolterandchainsword.com/topic/209660-daemonic-heralds/#findComment-2769418 Share on other sites More sharing options...
kalbik Posted May 27, 2011 Share Posted May 27, 2011 Here’s the one I’ve been working on. Still need some painting done. http://i404.photobucket.com/albums/pp128/Oftenwrong/warhammer/thc.jpg Link to comment https://bolterandchainsword.com/topic/209660-daemonic-heralds/#findComment-2773354 Share on other sites More sharing options...
Brother Ambroz Posted May 28, 2011 Share Posted May 28, 2011 Looks awesome kalbik. Link to comment https://bolterandchainsword.com/topic/209660-daemonic-heralds/#findComment-2773853 Share on other sites More sharing options...
Ayura Posted June 14, 2011 Share Posted June 14, 2011 Hi, i play pure khorne. For my heralds I use the hearld on juggrnaught from GW. And I use the hearld from Forge World that came with my Forge World Daemon Prince! Both very cool models Link to comment https://bolterandchainsword.com/topic/209660-daemonic-heralds/#findComment-2792691 Share on other sites More sharing options...
MarkDawg Posted July 29, 2011 Share Posted July 29, 2011 Here is mine Tzeentch http://i1188.photobucket.com/albums/z411/MarkDawg/hearld4.jpg Link to comment https://bolterandchainsword.com/topic/209660-daemonic-heralds/#findComment-2832634 Share on other sites More sharing options...
--eFTy--> Posted July 29, 2011 Share Posted July 29, 2011 Here's my Khorne Herald/BSB/Skulltaker. All plastic. :lol: http://i96.photobucket.com/albums/l164/eFTy_40k/TableTop/Chaos/Daemons/th_IMG_5138.jpg Link to comment https://bolterandchainsword.com/topic/209660-daemonic-heralds/#findComment-2832773 Share on other sites More sharing options...
