magnets
Hear da Lamentation
Guys, I really like using magnets for my models. BUT I have big problems keeping them glued on. The magnets are so strong, they stick together better than they stick to plastic models with glue.
Ive tried superglue - and plastic glue - neither are great.
What do you use?
https://bolterandchainsword.com/topic/209984-magnets/
What do you use?
Are you making sure that the holes you drill (to fit the magnets) are snug enough? They should be snug in the sense that if you drop a bit of super glue into the hole, it should never fall out.
https://bolterandchainsword.com/topic/209984-magnets/#findComment-2504688
What do you use?
Well, if all the suggestions above fail then how about certain bit more indirect means, like bit of paint or piece of paper between the magnets? Or changing the way ayou are handling those parts: like not pulling them apart, but sliding the contact surfaces of those magnetsaway from eachother?
https://bolterandchainsword.com/topic/209984-magnets/#findComment-2504875
1/8" drill bit for 1/8" rare earth magnets work wonders in space marines and their arms:
Whats that in mm?
I normally use 2mm magnets for arms, works well.
Just use 2mm drill bit to 2mm magnets. Just be carefull when drilling plastic, hole may go crooked if you let the drill move and then that magnet may not fit so well.
https://bolterandchainsword.com/topic/209984-magnets/#findComment-2504922
get some Araldite mate, its an epoxy and can stick steel girders togeather, its bloody strong stuff.
Bit OTT but that isn't realy anything particulary new, it is just a mater of how much force it can take per square inch or centimeter. What is realy cool is that velcro can hold easily 1kg/square cm.
https://bolterandchainsword.com/topic/209984-magnets/#findComment-2506405
