Sivil Posted September 10, 2010 Share Posted September 10, 2010 Hi all, i have been out of the game of 40k for the past 5 years and would like to rebuild my Dark angels army, I have read the codecs and like the look of a Ravenwing and Deathwing combo army is it a good idea or not? Link to comment https://bolterandchainsword.com/topic/210718-need-a-little-help/ Share on other sites More sharing options...
breng77 Posted September 10, 2010 Share Posted September 10, 2010 A Deathraven combo can be effective. If is a tough army to play as you will have very few models but if played correctly it can be very lethal. While certainly not a top tier army as far as competitiveness (no DA army is) it is one of the better builds DA can run, and the only truely unique build we have left. Link to comment https://bolterandchainsword.com/topic/210718-need-a-little-help/#findComment-2508779 Share on other sites More sharing options...
Anpu42 Posted September 10, 2010 Share Posted September 10, 2010 You can do what I eventualy Did Deathwing: Use the Dark Angels Codex Ravenwing: Use Codex Dark Angles or Codex Space Marines Normal Dark Angels Tactical: Codex Space Marines or Codex Blood Angels Link to comment https://bolterandchainsword.com/topic/210718-need-a-little-help/#findComment-2508786 Share on other sites More sharing options...
pueriexdeus Posted September 11, 2010 Share Posted September 11, 2010 The Deathraven build is very unique. And we are the only ones that can have it. As mentioned it is an unforgiving list to play and can be absolutely devastating. Though that is if you can play it. Link to comment https://bolterandchainsword.com/topic/210718-need-a-little-help/#findComment-2509084 Share on other sites More sharing options...
Alys Dwr Posted September 11, 2010 Share Posted September 11, 2010 ...but if played correctly... ...Though that is if you can play it. Forgive me, stepping in a bit here, but how should Sivil go about utilising his potential DW/RW army? Al (trying to be helpful) Link to comment https://bolterandchainsword.com/topic/210718-need-a-little-help/#findComment-2509591 Share on other sites More sharing options...
breng77 Posted September 11, 2010 Share Posted September 11, 2010 I have only used the list a few times myself. I think the basic strategy is to use the bikes to scout forward to teleport terminators in turn 1 (those that can DW assault) and then use the bikes to pop tanks and the termis to shoot up the troops inside. This also hopefully sets the termis up for an assault on turn 2 to finish off squads. The army is somewhat of a glass hammer as your model count will be low and if you don't do enough damage early you will likely go down to massed fire power. Link to comment https://bolterandchainsword.com/topic/210718-need-a-little-help/#findComment-2509660 Share on other sites More sharing options...
pueriexdeus Posted September 12, 2010 Share Posted September 12, 2010 I like to use my DR in combat teams, 6 bikes, AB, LS, and a squad of DW. A couple of things to keep in mind when using Deathraven is that the RW are not great in CC and the DW will have to get shot at before they can assault. So I'll use my RW to screen the DW and work them on the flanks of the OP. Here is an example. An isolated Sqd of Chaos on the right flank, maneuver the RW in combat Squads to threaten the target (close enough to charge), DS the DW and light up the target with everything and assault with one of the 3 bikes. Now you have probably taken out two or three of the opponents squad, they'll be tied up till the DW can assault next turn and the remaining 3 bikes, AB, and LS will be able to screen the combat from any OP support. This is just a brief example of how I use my DR. Obviously there are other tactics that can be used, and they mostly revolve around keeping the OP off balance, avoiding combat unless its on your terms, and putting the DW in the right place at the right time. Link to comment https://bolterandchainsword.com/topic/210718-need-a-little-help/#findComment-2509691 Share on other sites More sharing options...
