DGC Posted September 13, 2010 Share Posted September 13, 2010 I thought I would post up a step by step of basing trees in woods. Woods provide great cover for your troops and look great on the table but I have come across a couple of problems like minis falling off the terrain, not enough room for your unit on the base and the problem of the trees you use not standing up on their own. GW sell a pretty awesome plastic Woods set that gets around most of these problems but may not suit the trees or terrain you normally use. This tutorial will hopefully adress all the problems so you can use whatever trees you have and can easily be adapted to fit your own style using whatever bits you have at hand. For this tutorial you will need the following bits but feel free to substitute any with your own favored products / brands etc. Materials Trees 40mm round bases Base board (Masonite, Heavy card etc) 3mm Foamcore board Powdered plaster (Redimix, tile grout - whatever you use) Small broken dry twigs, some stones or similar, basing sand/gravel and static grass Tools Something to cut your chosen base board with (as I use a type of expanded plastic board I can get away using a heavy duty utility knife) File Something to cut holes (I used a Compass Cutter) Super Glue, PVA Glue Sculpting tool (for this topic I used the pointed end of a clean Kebab stick) and some Green Stuff or similar. First off you need to decide how big your woods are going to be. Place some of your chosen trees on a piece of board to get an idea of how many you will need (remeber that the trees do not have to be touching but too big a gap will look a little sparse when you try to claim that cover save), mark out then cut the board to shape. http://i149.photobucket.com/albums/s47/DGC_album/New%20trees/DSCN0955.jpg Using this base as a template, cut out a similar piece of foamcore http://i149.photobucket.com/albums/s47/DGC_album/New%20trees/DSCN0956.jpg Before you glue the two pieces together you will need to mark out where the trees will go and cut out some 41mm holes (the extra 1mm is to take into account the paint that will be applied to the tree bases, adding just that wee bit more to the 40mm base diameter) and check the 40mm bases fit in easily. When you are happy, bevel the edges of the boards, glue them together with PVA and allow to dry. In the following picture you can see I added a further piece of Foamcore at the back to add a little extra height and give a bit more character to the base. http://i149.photobucket.com/albums/s47/DGC_album/New%20trees/DSCN0957.jpg While the boards are drying you can get on with your trees. Take as many trees and bases as needed http://i149.photobucket.com/albums/s47/DGC_album/New%20trees/DSCN0946.jpg and carefully pull the trees away from their stumps. File the bottoms of the stumps flat (be careful as some stumps may be made from resin - wear a mask) http://i149.photobucket.com/albums/s47/DGC_album/New%20trees/DSCN0947.jpg then glue them to the 40mm bases using Super Glue http://i149.photobucket.com/albums/s47/DGC_album/New%20trees/DSCN0948.jpg Next we are going to blend the stumps into the bases using Green Stuff (GS) I tried two different ways of doing this. For the first method, mix up some GS and lay a ring around the base of the stump. http://i149.photobucket.com/albums/s47/DGC_album/New%20trees/DSCN0950.jpg Using your chosen sculpting tool blend the GS into the base using the roots of the stump as a guide. http://i149.photobucket.com/albums/s47/DGC_album/New%20trees/DSCN0951.jpg The second method just involves adding bits of GS to the root ends and giving them a bit of detail. http://i149.photobucket.com/albums/s47/DGC_album/New%20trees/DSCN0952.jpg Now back to the base whilst the GS cures Mix some plaster into a thick paste and add some PVA. Spread this goo over the base to blend the board and Foamcore together and to make up any difference in height between the base and the 40mm bases. Now we are going to add some extra detail to the base, just enough to add some character but not so much that we won't be able to stand figures up on it before the plaster mix dries to hard.` Here I have used tree bark pushed into the plaster while it was still wet to simulate rocks, http://i149.photobucket.com/albums/s47/DGC_album/New%20trees/DSCN0959.jpg some small twigs (from a dead Lavender plant) bent and snapped then glued into place and some patches of small gravel http://i149.photobucket.com/albums/s47/DGC_album/New%20trees/DSCN0960.jpg Allow to dry. The last part is to now cover the base with sand using slightly watered down PVA Repeat the basing on the tree stumps http://i149.photobucket.com/albums/s47/DGC_album/New%20trees/DSCN0953.jpg and allow all the bits to dry then finally give the base and stump bases a thin wash of watered down PVA to seal everything and allow to dry overnight. Next day test fit the trees again to make sure they fit. http://i149.photobucket.com/albums/s47/DGC_album/New%20trees/DSCN0964.jpg The next stage is painting. First, undercoat everything seperately and allow to dry then test fit again - we really don't want any problems now. (If neccesary run a file around the edge of the base to get it to fit again). http://i149.photobucket.com/albums/s47/DGC_album/New%20trees/DSCN0965.jpg As I wanted an aged look I lightly base coated the stumps and twigs with Scorched Brown. For the first stage of highlighting I added Codex Grey to the brown and lighly damp brushed the stumps. The next stage was more grey to the mix followed by adding a tiny touch of white to the mix. On one side of the stump I wanted to give the impression of moss and algae so I added a touch of Goblin Green to the third highlight mix and lightly drybrushed half the stump. A second lighter drybrush with a little Scorpion Green added to the mix and a final extreme highlight of pure Scorpion Green finished them of. http://i149.photobucket.com/albums/s47/DGC_album/New%20trees/DSCN0967.jpg The rocks on the bases were base coated 50/50 Chaos Black/Codex Grey The next highlight was done by adding more Codex Grey followed by one with a dash of Fortress Grey added to the mix and finally with a little Skull White as an extreme edge highlight. This was repeated on the rocks on the stump bases. Lastly a similar method for moss and algae was used to give some added colour http://i149.photobucket.com/albums/s47/DGC_album/New%20trees/DSCN0968.jpg The last bit is the ground colour. All my bases are done the same with the same colours so they go well together but use your own scheme so it fits with the rest of your terrain. I gave the base a light wash of very thinned Scorched Brown. When this had dried I gave a fairly heavy drybrush of Bestial Brown followed by a lighter drybrush of Bubonic Brown and a final light drybrush of Bleached Bone (the same was obviously done to the stump bases) http://i149.photobucket.com/albums/s47/DGC_album/New%20trees/DSCN0972.jpg When everything was dry I applied static grass in a patchy style to bring it all together. http://i149.photobucket.com/albums/s47/DGC_album/New%20trees/DSCN0973.jpg http://i149.photobucket.com/albums/s47/DGC_album/New%20trees/DSCN0974.jpg The last thing to do is to glue the trees back into the stumps with super glue and place them on the base - voila http://i149.photobucket.com/albums/s47/DGC_album/New%20trees/DSCN0975.jpg http://i149.photobucket.com/albums/s47/DGC_album/New%20trees/DSCN0976.jpg http://i149.photobucket.com/albums/s47/DGC_album/New%20trees/DSCN0977.jpg Hope you find this useful DGC Link to comment https://bolterandchainsword.com/topic/211037-basing-trees-in-woods/ Share on other sites More sharing options...
ravenguard2010 Posted September 13, 2010 Share Posted September 13, 2010 Awesome. Cheers. Link to comment https://bolterandchainsword.com/topic/211037-basing-trees-in-woods/#findComment-2510718 Share on other sites More sharing options...
ShinyRhino Posted September 13, 2010 Share Posted September 13, 2010 Nice work. Very finely detailed. One suggestion I'd make is painting the "holes" in the same brown as the rest of the base. That way, when you move them to make room for models, yu don't have the black void effect on the table. Link to comment https://bolterandchainsword.com/topic/211037-basing-trees-in-woods/#findComment-2510837 Share on other sites More sharing options...
augustmanifesto Posted October 14, 2010 Share Posted October 14, 2010 very, very nice tutorial. what plastic did you use for the base / where can it be purchased? Link to comment https://bolterandchainsword.com/topic/211037-basing-trees-in-woods/#findComment-2536139 Share on other sites More sharing options...
Zedrenael Posted October 21, 2011 Share Posted October 21, 2011 I like this idea. I will try it here shortly. Link to comment https://bolterandchainsword.com/topic/211037-basing-trees-in-woods/#findComment-2906000 Share on other sites More sharing options...
Foxmarine Posted October 23, 2011 Share Posted October 23, 2011 Thank you so much Link to comment https://bolterandchainsword.com/topic/211037-basing-trees-in-woods/#findComment-2906690 Share on other sites More sharing options...
6262 Posted December 13, 2011 Share Posted December 13, 2011 As a terrain building n00b how do you create those circular cuts on the foamboard? Thanks for the tutorial. Link to comment https://bolterandchainsword.com/topic/211037-basing-trees-in-woods/#findComment-2943610 Share on other sites More sharing options...
DGC Posted January 9, 2012 Author Share Posted January 9, 2012 The hole was cut with a compass cutter, basically a sharp blade in place of a pencil lead. http://i149.photobucket.com/albums/s47/DGC_album/modeling%20step%20by%20step/80-414-thickbox.jpg Link to comment https://bolterandchainsword.com/topic/211037-basing-trees-in-woods/#findComment-2962327 Share on other sites More sharing options...
Wolftracks8 Posted March 8, 2012 Share Posted March 8, 2012 Beautiful work. Link to comment https://bolterandchainsword.com/topic/211037-basing-trees-in-woods/#findComment-3010621 Share on other sites More sharing options...
arizonajirt Posted March 10, 2012 Share Posted March 10, 2012 looks good. i will be using this shortly. where did you get those trees from? i couldnt find them on the GW site. Link to comment https://bolterandchainsword.com/topic/211037-basing-trees-in-woods/#findComment-3012157 Share on other sites More sharing options...
Jacinda Posted March 13, 2012 Share Posted March 13, 2012 I don't know where he got those particular trees, but anywhere you buy models should have something similar. Just look around the model train area for some trees. For what it's worth, 40K scale is 1:40, more or less. O scale (1:48) fits well with 40K, but it is not all that popular of a scale for railroad hobbyists. It will also give you trees that tower over your vehicles and dreadnoughts. In a similar manner, S scale (1:64) fits 40K for larger natural structures like trees but is also hit and miss to find things in that scale. Mostly what you will find are in the HO (Half O - 1:87), N (1:160) and Z (1:220) scales. These scales will get you trees that are the shorter than your marine (Z scale) to about twice as tall depending on the scale and type of tree being modeled. And now that I have thrown all that out there, Woodland Scenics sells their trees by height. Just get the ones that look about right to you. Link to comment https://bolterandchainsword.com/topic/211037-basing-trees-in-woods/#findComment-3015240 Share on other sites More sharing options...
Ironfoe Posted April 16, 2012 Share Posted April 16, 2012 Oh man, those look as good as the GW produced pictures. Link to comment https://bolterandchainsword.com/topic/211037-basing-trees-in-woods/#findComment-3040390 Share on other sites More sharing options...
