Lord Kruge Posted September 15, 2010 Share Posted September 15, 2010 There was a rather heated discussion at the FLGS over this one, I'm thinking of running a MotF in my IH army, so I need the help of my Battle Brothers. Master of the Forge Base profile is 2 If I swap Bolter for Plasma Pistol and add Power Sword... that makes 3. Servo harness adds two S8 I1 attacks for a total of 5 (3 Power Weapon, 2 Servo-Arm) Does the twin-linked plasma pistol count as another CCW, thus raising attacks to 6? (4 Power Weapon, 2 Servo-Arm)? At one point I'm pretty sure it did, but not familiar with the new rulings for 5th. Link to comment Share on other sites More sharing options...
Montuhotep Posted September 15, 2010 Share Posted September 15, 2010 Afraid the plasma can only be fired, it can't be used in close combat (page 71, Marine Codex, Techmarine entry). Everything else is legal, though. :tu: Link to comment Share on other sites More sharing options...
Gaz1858 Posted September 15, 2010 Share Posted September 15, 2010 Servo harness adds two S8 I1 attacks for a total of 5 (3 Power Weapon, 2 Servo-Arm) Your total here is correct. Link to comment Share on other sites More sharing options...
Lord Kruge Posted September 15, 2010 Author Share Posted September 15, 2010 Afraid the plasma can only be fired, it can't be used in close combat (page 71, Marine Codex, Techmarine entry). Everything else is legal, though. :tu: Your total here is correct. Thanks :D Link to comment Share on other sites More sharing options...
greatcrusade08 Posted September 15, 2010 Share Posted September 15, 2010 sorry to jump in here but what do t-fire gunners get, had some confusion the other day.. Link to comment Share on other sites More sharing options...
Xeonic Posted September 15, 2010 Share Posted September 15, 2010 Thunderfire gunner is listed as having 1A, a bolt pistol and servo harness and no upgrade options. Thus I infer that he gets 1 attack+2 servo arm attacks, since it's listed nonsensically in the servo harness entry that the techmarine can't use his "plasma cutter" in CC. I say nonsensically because it's a plasma cutter, it should at the very least be able to be used in CC. An Elite techmarine could up this to 2 by purchasing a power weapon, his attacks would be 1(+1 offhand)+2 Servo arm. The MoTF that the OP mentions would have 3a with a plasma pistol and PW +2 servo arm attacks. You can never stack bonus attacks for more than 2 CCW(though it would almost make sense in this case, he already gets extra attacks from his harness!). Link to comment Share on other sites More sharing options...
spiros14 Posted September 15, 2010 Share Posted September 15, 2010 You cannot use the power sword to mix a combo of attacks, says so in the rulebook. if you want a flurry of attacks i think you have to replace it with a chainsword Link to comment Share on other sites More sharing options...
Frosty the Pyro Posted September 15, 2010 Share Posted September 15, 2010 You cannot use the power sword to mix a combo of attacks, says so in the rulebook. if you want a flurry of attacks i think you have to replace it with a chainsword you are wrong. Servo arms are aditional attacks ontop of the standard ones, and are not modified by the A profile or weapons weilded, or charging, or anything like that. So the powersword (which you had damn well better model as a techmarines cog ax) can be used for the MotF's standard attack I4 attacks, with the servo arms still going off at I1 as normal. Link to comment Share on other sites More sharing options...
spiros14 Posted September 16, 2010 Share Posted September 16, 2010 You cannot use the power sword to mix a combo of attacks, says so in the rulebook. if you want a flurry of attacks i think you have to replace it with a chainsword you are wrong. Servo arms are aditional attacks ontop of the standard ones, and are not modified by the A profile or weapons weilded, or charging, or anything like that. So the powersword (which you had damn well better model as a techmarines cog ax) can be used for the MotF's standard attack I4 attacks, with the servo arms still going off at I1 as normal. I did not mean the servo-arms (which if i recall might be power weapns anyway, i don't know) i meant the plasma pistol. Link to comment Share on other sites More sharing options...
KhorneHunter57x Posted September 16, 2010 Share Posted September 16, 2010 I did not mean the servo-arms (which if i recall might be power weapns anyway, i don't know) i meant the plasma pistol. Plasma Pistols are nothing special in CC (just like all pistols), they just count as one additional normal CCW. Link to comment Share on other sites More sharing options...
Gaz1858 Posted September 16, 2010 Share Posted September 16, 2010 Techmarine gunner bets 1 S4 attack and 2 servo arm attacks. A plasma pistol still counts as a pistol in cc so in addition to a power weapon will give +1A. Link to comment Share on other sites More sharing options...
