Glaeken Templaris Posted September 17, 2010 Share Posted September 17, 2010 Greeting Brother. Manged to find one of these beauties for just over a tenner in my local indy store so snapped it up for me sisters army. one issue ive noticed with the damn thing is getting those legs possitioned. Can anyone help with this. it is gonna be a case of drilling right thru the entire hole and pin them into possition or has anyone else come up with an alternative. The Emperor Protects Glaeken Link to comment https://bolterandchainsword.com/topic/211362-putting-together-a-penitant-engine/ Share on other sites More sharing options...
WarriorFish Posted September 17, 2010 Share Posted September 17, 2010 A bargain at £10! Surely it was the will of the Emperor that you found it, but he issued a challenge in the form of assembling it... Pinning is the best course of action as it'll give the model strength which will count for a lot otherwise it might explode in real life (as well as on the table...). Gel super glue has done wonders for me and my metal models so that is a viable alternative - put plenty on over as much surface area as you can and it'll make a strong bond. Use of blutack is the best way to hold the model while it glues, unless you have four hands. I'd recommend using both pinning and gel super glue for a strong bond that will not break easily. Link to comment https://bolterandchainsword.com/topic/211362-putting-together-a-penitant-engine/#findComment-2514553 Share on other sites More sharing options...
