Gealgain Posted September 19, 2010 Share Posted September 19, 2010 i'm looking to make my own standard issue blood angels jump pack list, and was wondering how viable it is to have typhoon land speeders as mobile support?, i'm looking to just use the land speeders as a fast but mobile heavy weapons platform (heavy bolter and missile launcher). friends of mine are saying I should just use a baal predator in my fast slot. however, i want the land speeders to be able to provide long range support as well as be able to fly high into cover if need be. (plus it fits with my theme of an all aerial assault 8th company) Link to comment https://bolterandchainsword.com/topic/211523-land-speeders-and-jet-packers/ Share on other sites More sharing options...
LordofDeath11 Posted September 19, 2010 Share Posted September 19, 2010 Sounds fun, could work too, but the best thing to do is try it out man. No amount of advie in the world will help you gauge a tactic as well as practical experience. Link to comment https://bolterandchainsword.com/topic/211523-land-speeders-and-jet-packers/#findComment-2516428 Share on other sites More sharing options...
Tame Posted September 19, 2010 Share Posted September 19, 2010 I run an all jump-packs army, and found the LS to work great. I usually go for 1 or 2 squads of 2 LS each, depending on the points, with 1 or 2 Vanguard Veterans squads with Storm Shields in the rest of the Fast Attack slots. My usual setup for the FA slot is something along the lines of: 2 Land Speeders with MM/HF, 2 Land Speeders with TML/HB, 1 Veteran Vanguard Squad with at least 3 Storm Shields and a Power Fist or 2 Land Speeders with TML/HB, 2 Veteran Vanguard Squad with at least 3 Storm Shields and a Power Fist The MM/MF are kamikaze ones, they are here to disrupt. The TML/HB ones are for long range support. VV tie down annoying shooty squads, trying to land with another squad nearby as support to open-up transports before if possible. I like the "aerial" theme, it's not something I would take in a competitive environnement, but it worked great in my friendly games so far. Link to comment https://bolterandchainsword.com/topic/211523-land-speeders-and-jet-packers/#findComment-2516448 Share on other sites More sharing options...
JamesI Posted September 19, 2010 Share Posted September 19, 2010 I took a land speeder typhoon to a recent tournament. It did pretty well for me, mainly keep it at range take advantage of the 36 inch range. Link to comment https://bolterandchainsword.com/topic/211523-land-speeders-and-jet-packers/#findComment-2516465 Share on other sites More sharing options...
Ozybonza Posted September 19, 2010 Share Posted September 19, 2010 I've been running this list: JP libby 4 x 10 man JP assault squads with splatterings of melta, flamer and PF 3 x JP priests w/PW 2 x typhoon 1 x typhoon 2 x MM/HF speeder I've played 2 games against the same CSM opponent (he took a different list each time) and I totally pwned both times. It's a great, fun list. Link to comment https://bolterandchainsword.com/topic/211523-land-speeders-and-jet-packers/#findComment-2516466 Share on other sites More sharing options...
garfey Posted September 20, 2010 Share Posted September 20, 2010 (plus it fits with my theme of an all aerial assault 8th company) Damm that was going to be my idea too! Lol. With a drop-pod furioso or DC dread or two thrown in for extra carnage! </thread hi-jack> Link to comment https://bolterandchainsword.com/topic/211523-land-speeders-and-jet-packers/#findComment-2516769 Share on other sites More sharing options...
Tame Posted September 20, 2010 Share Posted September 20, 2010 I took a land speeder typhoon to a recent tournament. It did pretty well for me, mainly keep it at range take advantage of the 36 inch range. You mean 48 :D Link to comment https://bolterandchainsword.com/topic/211523-land-speeders-and-jet-packers/#findComment-2517283 Share on other sites More sharing options...
I am Legion Posted September 21, 2010 Share Posted September 21, 2010 yeah marines are the easiest army to kill though. you have to try out that list VS nids and orks, even guard. When you find it works well consistently VS them, then you got a fearsome tournament list.... I'm yet to try it with the one I got. But I do like the idea, I tried something similar a long time ago when the codex came out, and the LS are great especially if you have a lot of marines for the enemy to shoot at. Like 2 devastators squads with 2-3 lascannons each, then 2-3 LS per squad of 2 and then just RAS with Priests. At 2000 points I had a very versatile list. Link to comment https://bolterandchainsword.com/topic/211523-land-speeders-and-jet-packers/#findComment-2517383 Share on other sites More sharing options...
JamesI Posted September 21, 2010 Share Posted September 21, 2010 I took a land speeder typhoon to a recent tournament. It did pretty well for me, mainly keep it at range take advantage of the 36 inch range. You mean 48 No, I was refering to firing the krak missiles and the heavy bolter. Link to comment https://bolterandchainsword.com/topic/211523-land-speeders-and-jet-packers/#findComment-2517417 Share on other sites More sharing options...
