Greystone Posted September 21, 2010 Share Posted September 21, 2010 I did some serching and did not find this topic covered, sorry if I missed it. I have just started in 40k and have done some trading with other players for a few kits lately. I wound up with the older land raider kit with the metal hurricane bolters, and no instructions... Looking at the parts I have no idea where to start. I'm hoping smoeone here has a link to, or can provide an assembly guide. Thanks in advance, Greystone. Link to comment https://bolterandchainsword.com/topic/211629-metal-hurricane-bolter-woes/ Share on other sites More sharing options...
Razblood Posted September 24, 2010 Share Posted September 24, 2010 Not sure if this will help but: The bolters have a nub at the back which fits into the main strut of the mount. The ammo feeds (sorta shaped like this: n), well the flat side fits onto the ammo boxes (theres a space on each large block on each mount) while the pronged ends fit around the main strut and connect to the backs of the bolters. I would recommend pinning everything or using a good epoxy glue as they do have a habit of breaking. Wish I had a camera so I could show each step, but I hope this at least helps a bit. also bluetack is your friend, try fitting everything together with it till it looks right :) Good luck with it. Link to comment https://bolterandchainsword.com/topic/211629-metal-hurricane-bolter-woes/#findComment-2519849 Share on other sites More sharing options...
