Taz Posted September 25, 2010 Share Posted September 25, 2010 I'm doing detail work on a Vanguard squad and I wanted to give the inside of the jump pack turbines a scorched, used look. I was thinking a devlan mud/badab black wash but I wanted to know if there's any other nifty way to make it look like the metal was recently subject to intense heat. Suggestions? Ideas? Link to comment https://bolterandchainsword.com/topic/211870-scorched-metal/ Share on other sites More sharing options...
Whitefireinferno Posted September 25, 2010 Share Posted September 25, 2010 A small bit of boltgun or Mithril around the edge either mixed with a mit of Blue or a Blue wash Link to comment https://bolterandchainsword.com/topic/211870-scorched-metal/#findComment-2520817 Share on other sites More sharing options...
Solid Zaku Posted September 25, 2010 Share Posted September 25, 2010 Hrm, I don't think a wash would be enough, even a heavy one. I'd actually go for a drybrush on the outer casing near the tips. Scorching+smoke doesn't equal a tasteful look it equals a metallic looking barbecue briquette. Link to comment https://bolterandchainsword.com/topic/211870-scorched-metal/#findComment-2520861 Share on other sites More sharing options...
winterdyne Posted September 25, 2010 Share Posted September 25, 2010 The effect you're looking for is called bronzing. If you look at the tips of afterburners on fighter jets, they frequently take a bronze / gold appearance. Once you've darkened down the metal with black drybrushes and those black / brown washes, apply a *very* fine drybrush of a little brown/gold mix, then a finer one of gold, and it should look the biz. Link to comment https://bolterandchainsword.com/topic/211870-scorched-metal/#findComment-2521243 Share on other sites More sharing options...
Taz Posted September 26, 2010 Author Share Posted September 26, 2010 The effect you're looking for is called bronzing. If you look at the tips of afterburners on fighter jets, they frequently take a bronze / gold appearance. Once you've darkened down the metal with black drybrushes and those black / brown washes, apply a *very* fine drybrush of a little brown/gold mix, then a finer one of gold, and it should look the biz. Â That sounds about right. Thanks for the help! Link to comment https://bolterandchainsword.com/topic/211870-scorched-metal/#findComment-2521387 Share on other sites More sharing options...
Ironfather_cogface Posted September 26, 2010 Share Posted September 26, 2010 Get a match/lighter and an old kitchen knife and hold it to the flame for a while (dont burn yourself of course). i think the colour is quite close to Boltgun metal washed over with Devlan/Badab mix, highlighted ever so gently with Brazen Brass Link to comment https://bolterandchainsword.com/topic/211870-scorched-metal/#findComment-2521528 Share on other sites More sharing options...
Rogue Trader Voril Posted September 26, 2010 Share Posted September 26, 2010 Drybrush black, then gold. Blen from gold down to bronze towards the black. http://i732.photobucket.com/albums/ww322/roguetradervoril/100_3665.jpg Link to comment https://bolterandchainsword.com/topic/211870-scorched-metal/#findComment-2521867 Share on other sites More sharing options...
Obliterator Posted September 26, 2010 Share Posted September 26, 2010 I typically do my scorched metal with a drybrush of Tin Bitz, followed by a Scorched Brown drybrush, and then a final drybrush of Chaos Black. This gives you a soot-y look like on my flamer nozzle below. For a heated metal like a jet exhaust, I'd follow Winterdyne's post. Also, look at pictures of what effect you're after; different metals give different effects. A jet engine exhaust will not be weathered the same way as a motorbike exhaust for example. Link to comment https://bolterandchainsword.com/topic/211870-scorched-metal/#findComment-2521899 Share on other sites More sharing options...
