How do I kill my opponent's thunderwolves?
lothbrok
i'm fully aware of the blasphemy inherent in this topic but i have to ask. how do you kill thunderwolves with sw short of massed vindicators.
the reason i ask is becuase i challenged a fellow wolf player to a grudge match and he always hearls excessive numbers of thunderwolves and at 3000 points i'm looking at a lot of fluffy fury.
Shoot them enough with anything. He can have max 22 Thunderwolf models between Lords, Iron Priests and TWC. You can put down 15 Missile Launchers as a counter, as well as plasma guns, melta guns, and a ridiculous amount of boltgun fire. Toss down some razorbacks and you have another few heavy bolters, assault cannons or whatever you wish. Dreadnoughts also work very well, as STR 10 still insta kills them in close combat. Rune priests can be really annoying, with either Jaws or Murderous hurricaine. Land speeders with either assault cannons or missile launchers would also do the trick. Terminators can stand up to their assaults and fight back, usually ripping a fair hole in them, and allowing a few more missile launchers.
The only other advice i can toss out is to play to the mission. With enough bodies on the table you can actually shrug off alot more than you think. at 2500 points I have 96 models in PA or Scout Armour and a Dreadnought kicking around. It takes alot to kill all of that, especially while its trying to killyou.
Do exactly the same? XD
Probably most seriously, you would probably mass as many Long Fangs and Land Speeders with missles as possible, and either mass your own rock (Either some thunder wolf of your own to counter him once he gets locked in combat, or wolf guard with Logan tooled up with a mix of stormshields, combiweapons, claws and hammers in termie armour to sit behind your defensive line to charge into him once he hits the grey hunter wall). or mass enough guys that you can unload your guys in bolter range and let rip with so many bolter shots, that wounds start getting through and have a few wolf guard to try and desprately kill them when they do reach close combat, just pile in.
Basically, either be even more offensive then him, or be prepaired to take the charge then hit him with everything you have. Enough Long Fangs and Typoohns force him to come up close, where you can wash him away with a solid counter attack via massed bolters and your smaller rock to wear him out.
Ragnar
Ulrik
8 PA Wolf Guard with pistol and power weps + one Arjac Rockfist
in a Land Raider Redeamer
31A base +(10xD3) on the charge with power weps that reroll hits AND wounds followed by 5-7 S10 from Arjac
is Fearless and Stubbern that can sneak in a Furious Charge
all for under 1100 points...... how could you lose?
I borrowed the imperial codex to have a look, it is actually 3 blasts.
Did it used to be 5? In that case, you don't need anti infantry, just lots of anti tank and lots of Russ excutioners. Since they would scatter so much that everything around it would die. XD
No, but it can have two plasmacannon sponsons- atleast one of wich can fire on the move.
True enough, I actually forgot it would take them, though it makes sense, if only to allot a destoryed result to one of them. Just I made a list with two of these guys in to pass some time, perhaps I need to cut back on the good stuff a little. XD
My usual weekly opponent and I both play space wolves, and he also runs 2 packs of wolves. We usually play at 3000 pts. He runs them in two groups of two with one power fist /storm shield and ccw / storm shield. Attached to them is a wolf lord with wolf claws and belt of russ, with different sagas each. This combo is deadly effective. I have dropped my entire armies worth of fire power into them and still did not completely take them out. Only advice I can offer is shoot them at range, try to use a dread as a counter assualt, and above all else play the mission and hope we cant take you out before the end of the game!
i was thinking a list something like this
ragnar
ulrik
landraider crusader
wgx7 tda fbx4 th combi-meltax2 ssx4 wcx2
long fangs 3 missile luanchers 2 lasscannon razorback rwin assualt cannon
longfangs 5 heavy bolters
predator twin lass heavy bolter sponson
3xgrey huntersx10 pw mow ws 2xmelta plasm pistol rhino hunterkiller
grey huntersx10 pw mow ws meltax2 drop pod deathwind
2xven dread wtn wtt multi melta drop pod deathwind
the plan was to drop in the dreads and attempt to neutralize his vindicators (1 or 2 of those) and then pump everything else into his thunderwolves before rushing ragnar ulrik and the wolfguard in to hopefully annihilate anything they touch in close combat while using the grey hunters to seize objectives or sluaghther their counterparts.
criticism is more than welcome
