Librarian Conversion
What things do I need to include on a kitbashed librarian to show that it is, in fact, a librarian? I'm thinking a psychic hood of some sort and a CC weapon other then a chainsword? I finally decided to paint my models as Dark Angel's, so what color should its armor be? I think I'm going to use the power sword from the DA upgrade (the terminator one) but put the blade on a pole so his weapon will be a halberd. Where can I get a nice little stick for him to use as the halberd shaft?
https://bolterandchainsword.com/topic/212854-librarian-conversion/
Pole: Chaos Marine 10-man squad or in the Command Squad.
If you want to actually have the sword you speak of, there is one for power armour in the Ravenwing box for the sergeant. You can also use the various DA icons that go on top of banners and such to make a staff like a regular Librarian, works well for Chaplains too. I myself kitbashed a Chaplain in power armour and custom made a crozius using this method.
You can easily make one of those helmets without having to cut into the metal of the watcher (let alone get one seperate from Az). In one of the DA bits kits, veterans I believe, are some plastic helmet wings you can add to a helmet of your choice. Much easier and cheaper then the watcher option.
