Spazmonkey Posted October 11, 2010 Share Posted October 11, 2010 Saga of the hunter states "infantry only" But under the WGBL discription the only exclusion is that the unit must be in power Armor. Im assuming you cant but, can you buy a WGBL with SOH as he meets the qualifer of infantry, then purchase the TWM and use outflank? Or does buying the TWM after buying SOH cancel the SOH ability as it becomes a cav unit? Link to comment https://bolterandchainsword.com/topic/212920-wgbl-on-twm/ Share on other sites More sharing options...
Godhead Posted October 11, 2010 Share Posted October 11, 2010 A TWM changes the unit type to cavalry. So that means no saga of the hunter. Link to comment https://bolterandchainsword.com/topic/212920-wgbl-on-twm/#findComment-2532995 Share on other sites More sharing options...
Marshal Wilhelm Posted October 11, 2010 Share Posted October 11, 2010 Saga of the hunter states "infantry only"But under the WGBL discription the only exclusion is that the unit must be in power Armor. Im assuming you cant but, can you buy a WGBL with SOH as he meets the qualifer of infantry, then purchase the TWM and use outflank? Or does buying the TWM after buying SOH cancel the SOH ability as it becomes a cav unit? Being Cav stops SotHunter. You can't buy things in order. The whole package has to work together. Link to comment https://bolterandchainsword.com/topic/212920-wgbl-on-twm/#findComment-2532996 Share on other sites More sharing options...
Spacefrisian Posted October 11, 2010 Share Posted October 11, 2010 These weird echos all the time. LOL Link to comment https://bolterandchainsword.com/topic/212920-wgbl-on-twm/#findComment-2533287 Share on other sites More sharing options...
