BrotherGrimm Posted October 12, 2010 Share Posted October 12, 2010 awhile back there was a space wolf termie conversion uesing the arm-guards from the command sprue and the termie flamer with the nozzles cut off and replaced with what looked like 2 cut-down heavy bolters. I tried the sercy but my serch-fu is weak, any help finding out who did the conversion or pics would be greatly appreciated*g* Link to comment https://bolterandchainsword.com/topic/213033-termie-conversion/ Share on other sites More sharing options...
Growler67 Posted October 12, 2010 Share Posted October 12, 2010 So how is your Google-Fu? http://members.armourarchive.org/teufel/Miniatures/CLOUSEAU%20-%20True%20Scale%20Space%20Wolf%20Terminator%205.JPG From this thread: www.dakkadakka.com/dakkaforum/posts/list/207935.page ETA: Link intentionally left cold. Link to comment https://bolterandchainsword.com/topic/213033-termie-conversion/#findComment-2534517 Share on other sites More sharing options...
Wolf Lord Mjolnir Posted October 13, 2010 Share Posted October 13, 2010 Or do you mean my Pre Heresy reaper autocannon space wolf? http://i255.photobucket.com/albums/hh132/Mjolnir81/P9110026.jpg More on my blog. Link to comment https://bolterandchainsword.com/topic/213033-termie-conversion/#findComment-2535574 Share on other sites More sharing options...
Tyleesa Posted October 13, 2010 Share Posted October 13, 2010 Or do you mean my Pre Heresy reaper autocannon space wolf? http://i255.photobucket.com/albums/hh132/Mjolnir81/P9110026.jpg More on my blog. How did you make the helmet and the shoulderpads? Link to comment https://bolterandchainsword.com/topic/213033-termie-conversion/#findComment-2535640 Share on other sites More sharing options...
BrotherGrimm Posted October 14, 2010 Author Share Posted October 14, 2010 yep thats one of them Wolf Lord Mjolnir fantastic work*g*do youhave any wip of how you built them? it would be greatly appreciated *g* Link to comment https://bolterandchainsword.com/topic/213033-termie-conversion/#findComment-2535840 Share on other sites More sharing options...
CainTheHunter Posted October 14, 2010 Share Posted October 14, 2010 How did you make the helmet and the shoulderpads? These are steam knights helmets and shoulderpads from Maxmini Link to comment https://bolterandchainsword.com/topic/213033-termie-conversion/#findComment-2535927 Share on other sites More sharing options...
Marshal Wilhelm Posted October 14, 2010 Share Posted October 14, 2010 Or do you mean my Pre Heresy reaper autocannon space wolf? Mjolnir, your blog stuff is A-Mazing! I assume you are also WLM on The Great Crusade? I am wondering how you have done such a job with your GS hair and fur? I can chop and kit bash well enough, but my GSing is limited to filling gaps and making Templar robes blend around for Terminators. What does one do to grow GS skill, I mean, are there incremental things to do in getting better? Link to comment https://bolterandchainsword.com/topic/213033-termie-conversion/#findComment-2535981 Share on other sites More sharing options...
LPetersson Posted October 14, 2010 Share Posted October 14, 2010 Or do you mean my Pre Heresy reaper autocannon space wolf? http://i255.photobucket.com/albums/hh132/Mjolnir81/P9110026.jpg More on my blog. Wow, that is amazing stuff... Would you mind terribly listing the non-GW/FW stuff you've used in addition to the steam knight helmets and shoulderpads? Link to comment https://bolterandchainsword.com/topic/213033-termie-conversion/#findComment-2535997 Share on other sites More sharing options...
Wolf Lord Mjolnir Posted October 14, 2010 Share Posted October 14, 2010 Glad you like them guys. You can find comments on the termie construction and other termie images on this page of my blog. The heads are from max mini and the shoulder pads have been made using oil drums from the Tamiya jerry can set. The only tips I can give with GS is to practice and always keep your sculpting tool wet by dipping it quickly into water. Some people like to use vaseline or some other oil based product but I don't like the greasy feel. Also, water can simply be mopped up! :wacko: I suppose on thinking about it the next best tip is to not feel you have to make the final product out of GS in one go. Make a section of the final piece - let that set and then build up on it. That is how I built my model for Leman Russ. I also experimented with milliput as this can be filed to a very fine finish and hard edges are easier to sculpt. Mjol Link to comment https://bolterandchainsword.com/topic/213033-termie-conversion/#findComment-2536012 Share on other sites More sharing options...
Inquisitor Kravin Posted October 14, 2010 Share Posted October 14, 2010 I've been using my own Logan Wing army as an opportunity to get serious about sculpting parts and details. I've found Milliput better that Greenstuff for a lot of pieces. It takes longer to set so you have more time to work with it and when it does finally dry it is harder making it easier to work with needle files to file down and get crisp, sharp edges. Theo nly downside to milliput is that it can be a little more brittle so for something like beard braids greenstuff is a bit more resilient because it will flex a little. Link to comment https://bolterandchainsword.com/topic/213033-termie-conversion/#findComment-2536055 Share on other sites More sharing options...
Kreon Posted October 14, 2010 Share Posted October 14, 2010 Glad you like them guys. You can find comments on the termie construction and other termie images on this page of my blog. The heads are from max mini and the shoulder pads have been made using oil drums from the Tamiya jerry can set. The only tips I can give with GS is to practice and always keep your sculpting tool wet by dipping it quickly into water. Some people like to use vaseline or some other oil based product but I don't like the greasy feel. Also, water can simply be mopped up! :) I suppose on thinking about it the next best tip is to not feel you have to make the final product out of GS in one go. Make a section of the final piece - let that set and then build up on it. That is how I built my model for Leman Russ. I also experimented with milliput as this can be filed to a very fine finish and hard edges are easier to sculpt. Mjol Just went through your entire blog. That is a beautiful force. Link to comment https://bolterandchainsword.com/topic/213033-termie-conversion/#findComment-2536099 Share on other sites More sharing options...
