Jakobus Posted October 14, 2010 Share Posted October 14, 2010 Just looking at some ideas of basing some gaming tables around local landmarks and trying to figure out what a semi realistic scale I should be considering. Am I right or at least close in saying approximately 1/40 scale Link to comment https://bolterandchainsword.com/topic/213121-40k-scale/ Share on other sites More sharing options...
Viray Posted October 14, 2010 Share Posted October 14, 2010 I think it's 1/56, but I could be wrong. Link to comment https://bolterandchainsword.com/topic/213121-40k-scale/#findComment-2535758 Share on other sites More sharing options...
Gurth Posted October 14, 2010 Share Posted October 14, 2010 If you go strictly by model height, I'd say about 1/60 — that is, Imperial Guardsmen are about 3 cm tall, so if you assume they'd be about 1.80 m IRL that makes them 1/60th scale. However, the models are actually rather cartoonish so you can't really say they've got a true scale like, for example, model kits do. If I were you I'd start with the 1/60th scale and adjust the actual size of your table's features as seems to fit the models and available room best. Link to comment https://bolterandchainsword.com/topic/213121-40k-scale/#findComment-2535935 Share on other sites More sharing options...
winterdyne Posted October 14, 2010 Share Posted October 14, 2010 You'll also find that real-scale hills and things are far too massive for wargaming on a typical dining room size table. You need to exaggerate height on terrain (steeper / stepped hills to block LOS etc). Link to comment https://bolterandchainsword.com/topic/213121-40k-scale/#findComment-2536291 Share on other sites More sharing options...
madscuzzy Posted October 14, 2010 Share Posted October 14, 2010 GW scale is between 1/48 and 1/35, and either line of models can work, especially if you are looking into buildings or vehicle accessories . So yes you are pretty close at 1/40. 1/60 is more common place when looking at model kits that bandai makes, such as gundams, macross, power rangers etc. Link to comment https://bolterandchainsword.com/topic/213121-40k-scale/#findComment-2536353 Share on other sites More sharing options...
