Myxx Posted October 18, 2010 Share Posted October 18, 2010 A couple of questions for my more learned collegues here... I want to add some inducted IG to my WH army, and I noticed that C:WH lists IG platoons as troops choices. Was there a change in terminology between editions or did the old edition platoon have quite as large a make-up as the current C:IG platoon list. I mean, 1 command squad, 2-5 infantry squads, 0-5 heavy weapons squads and 0-2 special weapons squads seems like a lot of bodies, especially when you have to take 2 of them to unlock the FA or HS options. Does the rule mean this entire mob of IG units or does it simply mean a single squad (i.e. a 10 man infantry unit per troops choice)? And I suppose the easier question: Inducted IG allows for an 0-1 Leman Russ tank. Does that mean any variant of the Leman Russ (Punisher, Vanquisher, etc.) or only the "stock" version? Thanks for any help. Link to comment https://bolterandchainsword.com/topic/213468-using-inducted-guard-with-witch-hunters/ Share on other sites More sharing options...
Chengar Qordath Posted October 19, 2010 Share Posted October 19, 2010 GW's Imperial Guard FAQ has the answers. Link to comment https://bolterandchainsword.com/topic/213468-using-inducted-guard-with-witch-hunters/#findComment-2539898 Share on other sites More sharing options...
Myxx Posted October 19, 2010 Author Share Posted October 19, 2010 Thanks. I see the tank question (*facepalm* - probably shoulda checked the official website first). Link to comment https://bolterandchainsword.com/topic/213468-using-inducted-guard-with-witch-hunters/#findComment-2539925 Share on other sites More sharing options...
