Leardinal Posted October 21, 2010 Share Posted October 21, 2010 Hey all, I am reworking my fluff, and was wondering if anyone would object to the Chapter Master being in charge of the 1st Company, essentially becoming its "Captain." The reasoning I have is that although the responsibilities of being a Chapter Master and of being a Captain would seem to be too much for even a Space Marine, The first company is usually spread out among the other companies, leaving the rest in the Fortress Monastery and the decreasing the need for a true Captain. Wow, I actually thought I had more to back up this thought... I may have interpreted something the wrong way so feel free to give me a virtual slap. Link to comment https://bolterandchainsword.com/topic/213625-chapter-master-and-1st-company-captain/ Share on other sites More sharing options...
Ecritter Posted October 21, 2010 Share Posted October 21, 2010 Not horrible at all, I'm already using it in the chapter I'm working on now. Just need to have a really good reason I guess. Link to comment https://bolterandchainsword.com/topic/213625-chapter-master-and-1st-company-captain/#findComment-2541973 Share on other sites More sharing options...
Leardinal Posted October 21, 2010 Author Share Posted October 21, 2010 Thanks for the reply. Now I just have to come up with a reason, (which should be simple enough) Link to comment https://bolterandchainsword.com/topic/213625-chapter-master-and-1st-company-captain/#findComment-2541986 Share on other sites More sharing options...
Ecritter Posted October 21, 2010 Share Posted October 21, 2010 Thanks for the reply. Now I just have to come up with a reason, (which should be simple enough) Reason .... easy Good Reason .... not so easy Only time will show if the reason I gave passes the test. Best of luck with yours. Link to comment https://bolterandchainsword.com/topic/213625-chapter-master-and-1st-company-captain/#findComment-2541989 Share on other sites More sharing options...
Leardinal Posted October 21, 2010 Author Share Posted October 21, 2010 Thanks for the reply. Now I just have to come up with a reason, (which should be simple enough) Reason .... easy Good Reason .... not so easy Only time will show if the reason I gave passes the test. Best of luck with yours. So true, but if mine is no good I will just rethink it, (as long as I don't get oddly attached to it by over thinking.) Best of luck to your idea as well Link to comment https://bolterandchainsword.com/topic/213625-chapter-master-and-1st-company-captain/#findComment-2541994 Share on other sites More sharing options...
