Warband idea
Captain Jack
Could a renegade war band Be a fleet of rogue chapters
A fleet of entire Chapters seems unlikely, a force that big would be getting to the point of 'why haven't GW mentioned them already'.
However, if you mean a warband and fleet comprised of various smaller renegade squads/companies/ships from several different Chapters, I figure that would be fine; and probably be quite interesting to write/read in terms of the internal politics of the warband.
https://bolterandchainsword.com/topic/213702-warband-idea/#findComment-2543219
Sure. In fact I would think this would almost be the norm. Not entire chapters mind you, but a conglomeration of a handful of marines from a bunch of different chapters. Afterall, whole chapters rarely turn Chaos, but small factions and splinter groups happen all the time. Every chapter has had marines turn Chaos, makes sense that they wanna work with others to unify their strength.
https://bolterandchainsword.com/topic/213702-warband-idea/#findComment-2543224
The Red Corsairs are a good example of this. Although the core of the traitor force is based on the fallen chapter the Astral Claws, they take in many renegades from other chapters to expand their numbers. It is quite reasonable that another such warband has appeared elsewhere in the Imperium.
https://bolterandchainsword.com/topic/213702-warband-idea/#findComment-2543246
the Concept is that a chapter was deemed excommunicate do to their actions in a battle but other chapters at the battle spoke out were also deemed excommunicate and they formed a fleet dedicated to defying the imperium essentially a federation of rogue astartes
https://bolterandchainsword.com/topic/213702-warband-idea/#findComment-2543657
Well, the thing is, this scenario seems unlikely. Unless the instance was pretty darn bad, the other chapters backing them up would generally be enough. If it was that bad, why would the other chapters back them up? Secondly, I doubt the Inquisition is gonna let more than one chapter run about. They wouldn't declare you all Excommunicate, they would just destroy you all.
That's just my opinion though. Seems pretty unlikely.
https://bolterandchainsword.com/topic/213702-warband-idea/#findComment-2543724
It might work if they were the companies of chapters (probably best to use battle companies as opposed to first companies, reserves and scouts), that's only 100 marines per chapter as opposed to 1000. They'd take losses during the battle, and then during any conflicts as they escape the system, so 2 or 3 companies from 2-3 chapters could end up as a renegade force of around 200 depending on losses suffered between them. 200 Marines seems like a decent amount for a warband to start pirating at least, perhaps gaining the attention of lesser warbands as they do so.
You'd need to be careful though, perhaps have them hunted by the crusading chapters they splintered from (crusading as repentance for letting taint corrupt some of their brothers, perhaps?). You'd need to be able to work it into fluff though, so no using Flesh Tearers or another well known chapter to split from, but you can't just use any old chapter either, as GW could choose to expand their fluff at any point, making yours incorrect.
https://bolterandchainsword.com/topic/213702-warband-idea/#findComment-2543730
Chapter A B and C are fighting together in the Placeholder System. the members of chapter A save civilians rather than a noble house against orders. the campaign in placeholder system has been going on for along time and the chapters bonded. chapter A is declared Excommunicate. chapter A is attacked by the inquisition other chapters see their comrades being attacked They barely make it out alive and become a traitor fleet. Or maybe a lot of different companies
Or
Badab War esque rebellion with much more loyal allies Pirate fleet that funds and supports rebellions. Except since it would be after the original Badab War they would just leave rather than fighting
which would be a more logical
https://bolterandchainsword.com/topic/213702-warband-idea/#findComment-2543745
