Deschenus Maximus Posted October 24, 2010 Share Posted October 24, 2010 Simple enough question: how do you arrive at a smooth finish when filing? Whenever I do it, it seems like the filed area is scratched and grooved. I'm mainly talking about erasing BA blood drops from DC components. Link to comment https://bolterandchainsword.com/topic/213803-smooth-filing/ Share on other sites More sharing options...
Prosedragon Posted October 25, 2010 Share Posted October 25, 2010 I feel your pain - I've always gotten the best results from just a sharp razor blade. My thumb might dispute that contention... Link to comment https://bolterandchainsword.com/topic/213803-smooth-filing/#findComment-2544419 Share on other sites More sharing options...
Xeonic Posted October 25, 2010 Share Posted October 25, 2010 Once you've filed the area down, I find that going over it with several passes of successively finer sandpaper does the job. But yes, for small stuff a sharp razorblade(your thumb should never be a full stop!) produces better results with less work. Link to comment https://bolterandchainsword.com/topic/213803-smooth-filing/#findComment-2544429 Share on other sites More sharing options...
Hemal Posted October 25, 2010 Share Posted October 25, 2010 Or you file along the model. The needle files should produce a relatively smooth finish - though as suggested fine grit sandpaper produces a much smoother surface. Link to comment https://bolterandchainsword.com/topic/213803-smooth-filing/#findComment-2544467 Share on other sites More sharing options...
Olgerth Istaarn Posted October 25, 2010 Share Posted October 25, 2010 Use emery boards after you scrape the majority off with the knife (found at any pharmacy). Someone gave me this advice on this board earlier ;) An emery board is essentially sandpaper-on-a-stick, you can cut it down to size if necessary, and they come in very fine grits. Link to comment https://bolterandchainsword.com/topic/213803-smooth-filing/#findComment-2544572 Share on other sites More sharing options...
MajorKhaos Posted October 26, 2010 Share Posted October 26, 2010 I use these pads. http://www.diy.com/diy/jsp/bq/nav.jsp?acti...p;isSearch=true They can be cut up into small pieces and being sponge backed are flexible so cn easily folow the contors of the model better than files / sandpaper. Link to comment https://bolterandchainsword.com/topic/213803-smooth-filing/#findComment-2545266 Share on other sites More sharing options...
winterdyne Posted October 26, 2010 Share Posted October 26, 2010 The general rule of thumb is the tools do the work, not the muscle. I think you may be pressing too hard on the file, and pulling it back and forth. Try less pressure, more directions (file in a circular motion or regularly change angle) and a finer file. Then sand. Grooving is usually a sign you've put way too much pressure on the piece and worked too much in one direction. Also remember to clean away material regularly (especially on metal) as this can build up and cause scratching too. Also; some files have a particular cutting direction - usually back (toward the handle) - when pulling it this way keep the pressure on the piece particularly light. Link to comment https://bolterandchainsword.com/topic/213803-smooth-filing/#findComment-2545475 Share on other sites More sharing options...
