uhefter Posted October 27, 2010 Share Posted October 27, 2010 I'm just starting a Imperial Fists Battle Force. I've got the shade of yellow I like, but I'm having trouble highlighting (or dark-lighting) the cracks and spaces in the power armor. I've seen some posts about running "watered down ink" into the indentions, but my question is, should I go buy some ink, or, can I water down some paint? And If so, what's the ratio? Has anyone tried this before? Does anyone have any tips? Thanks all. Link to comment https://bolterandchainsword.com/topic/213992-inks-vs-watered-down-paint/ Share on other sites More sharing options...
The Black Watch Posted October 27, 2010 Share Posted October 27, 2010 You can water them down if you feel like it. The GW one's are 'ready made' though. I can't remember the ratio I use - I just keep adding more water until it looks right! Link to comment https://bolterandchainsword.com/topic/213992-inks-vs-watered-down-paint/#findComment-2546655 Share on other sites More sharing options...
novasminis Posted October 27, 2010 Share Posted October 27, 2010 buying the inks is well worth it, when using watered down paints its much easier to get rings where the paint spreads and dries at the edges of the bits you put down (due to surface tension and oils on the model) I find using the inks means you dont have to be as careful and will save some time. Link to comment https://bolterandchainsword.com/topic/213992-inks-vs-watered-down-paint/#findComment-2546658 Share on other sites More sharing options...
Tanhausen Posted October 27, 2010 Share Posted October 27, 2010 To break tension, add window cleaner... 10 water:1 windowcleaner Link to comment https://bolterandchainsword.com/topic/213992-inks-vs-watered-down-paint/#findComment-2546670 Share on other sites More sharing options...
