Bat33.1 Posted October 27, 2010 Share Posted October 27, 2010 Just wondering if there are any refrences to Space Wolves using chain axes as everything I've seen so far only mentions chainswords? I was considering adding some chain axes in a new build... Link to comment https://bolterandchainsword.com/topic/214003-chain-axes-for-wolves/ Share on other sites More sharing options...
Max_Dammit Posted October 27, 2010 Share Posted October 27, 2010 I love chain axe on SW, Got one on my thunder mount. So i say go for it Link to comment https://bolterandchainsword.com/topic/214003-chain-axes-for-wolves/#findComment-2546903 Share on other sites More sharing options...
Grimtooth Posted October 27, 2010 Share Posted October 27, 2010 Considering that almost all the fluff regarding Fenrisians, it is all about the axes so go for it. I personally am using two chain axes with shortened shafts on on of my MoW models. Link to comment https://bolterandchainsword.com/topic/214003-chain-axes-for-wolves/#findComment-2546943 Share on other sites More sharing options...
Rune_Priest_Rhapsody Posted October 27, 2010 Share Posted October 27, 2010 I recently traded for three of the things for using with special models. I like the idea of using them for the MOtW models, good idea Brother Ramses!! -R_P_R Link to comment https://bolterandchainsword.com/topic/214003-chain-axes-for-wolves/#findComment-2546949 Share on other sites More sharing options...
Sarapham Posted October 27, 2010 Share Posted October 27, 2010 I use chain-axes on all my "claw"-types, both because it is always hardcore with an axe and also because in Viking times axes were more common than swords... so I use sword for the higher tiered units. Link to comment https://bolterandchainsword.com/topic/214003-chain-axes-for-wolves/#findComment-2546956 Share on other sites More sharing options...
fivepointedstar Posted October 27, 2010 Share Posted October 27, 2010 Is the only place to get chain-axes is with the berzerkers box? where else do you find them at? Link to comment https://bolterandchainsword.com/topic/214003-chain-axes-for-wolves/#findComment-2546982 Share on other sites More sharing options...
Grimtooth Posted October 27, 2010 Share Posted October 27, 2010 Is the only place to get chain-axes is with the berzerkers box? where else do you find them at? They can also be bought from Forge World. Link to comment https://bolterandchainsword.com/topic/214003-chain-axes-for-wolves/#findComment-2547018 Share on other sites More sharing options...
Bat33.1 Posted October 27, 2010 Author Share Posted October 27, 2010 Only trouble with the FW chainaxes they are quite fragile I've used them in the past and they do look the part but they are difficult to to keep in one piece Link to comment https://bolterandchainsword.com/topic/214003-chain-axes-for-wolves/#findComment-2547030 Share on other sites More sharing options...
Prot Posted October 27, 2010 Share Posted October 27, 2010 Only trouble with the FW chainaxes they are quite fragile I've used them in the past and they do look the part but they are difficult to to keep in one piece Agreed. I had lots and they're tough to drill into the fists of plastic arms (they come as a separate weapon, no arms), and they are extremely brittle. The tiniest bend could make them snap. Link to comment https://bolterandchainsword.com/topic/214003-chain-axes-for-wolves/#findComment-2547034 Share on other sites More sharing options...
Orphus Posted October 27, 2010 Share Posted October 27, 2010 Chainaxes are great, i'm considering one for my Wolf Priest as a 'counts-as' Crozius because I think it would look cooler (and would fit with his fluff). I'm not so sure about the forgeworld stuff if it's as brittle as you say. Is there a bitz pack with Chainaxes or will i have to resort to buying some Bezerkers? Link to comment https://bolterandchainsword.com/topic/214003-chain-axes-for-wolves/#findComment-2547096 Share on other sites More sharing options...
Blarmb Posted October 27, 2010 Share Posted October 27, 2010 Besides the entry for most SW units just reads "Close Combat Weapon" which could be just about anything, so long as it's suitably pointy, slashy and/or bashy. Considering the whole Individuality theme SWs going, I don't really think you need precedence in the fluff for a particular weapon. After all who is say to any given Wolf isn't just fond of whatever odd weapon he decides to use? Potenially you could have a wolf that on same planet picked up and decided he liked a pair of nunchucks or possibly chain-chucks (granted both of these might feel a bit out of place in 40k, and chain-chucks are particularly silly). I've been considering remolding each of my backs such that they have different preffered weapons. One pack uses Chainswords, another uses Spears, another might use chainaxes, while one just uses combat knives. Etc... There really isn't any reason to limit yourself. Link to comment https://bolterandchainsword.com/topic/214003-chain-axes-for-wolves/#findComment-2547158 Share on other sites More sharing options...
MaveriK Posted October 28, 2010 Share Posted October 28, 2010 Just wondering if there are any refrences to Space Wolves using chain axes as everything I've seen so far only mentions chainswords? I was considering adding some chain axes in a new build... yeah in the Space Wolf codex, pg 18. there is a picture, battle against the Tau.. and you see a Space Wolf with a chain axe. Also its in the Frost blade or Axe description on pg 57. Also a picture of a chainsword like Frost blade in pg 59 called kraken tooh pattern. Link to comment https://bolterandchainsword.com/topic/214003-chain-axes-for-wolves/#findComment-2547180 Share on other sites More sharing options...
Stormshrug Posted October 28, 2010 Share Posted October 28, 2010 Don't stop at axes, I say. Spears, knives, maces, beer steins, month-old shanks of mammoth, chairs - to a true warrior, anything is a weapon! -Stormshrug Link to comment https://bolterandchainsword.com/topic/214003-chain-axes-for-wolves/#findComment-2547192 Share on other sites More sharing options...
Grimtooth Posted October 28, 2010 Share Posted October 28, 2010 Don't stop at axes, I say. Spears, knives, maces, beer steins, month-old shanks of mammoth, chairs - to a true warrior, anything is a weapon! -Stormshrug Half of those are beer hall weapons, half are battlefield. Link to comment https://bolterandchainsword.com/topic/214003-chain-axes-for-wolves/#findComment-2547214 Share on other sites More sharing options...
Focke Posted October 28, 2010 Share Posted October 28, 2010 Is there really that big of a difference to the sons of Russ? Link to comment https://bolterandchainsword.com/topic/214003-chain-axes-for-wolves/#findComment-2547382 Share on other sites More sharing options...
slmellon Posted October 28, 2010 Share Posted October 28, 2010 Does that mean I could model, say, a GH swinging an Ork leg as a CCW? With an legless Ork on the base? Link to comment https://bolterandchainsword.com/topic/214003-chain-axes-for-wolves/#findComment-2547811 Share on other sites More sharing options...
The_son_of_Dorn Posted October 28, 2010 Share Posted October 28, 2010 i use it on my blood drinker captain and give it the stats of a "relic blade" plus shiny paint job ;) Hes the only one to weild it though as it is a relic and thusly considerd holy :) Anyone other squad member is a straight up NO though thats my personal opinion Link to comment https://bolterandchainsword.com/topic/214003-chain-axes-for-wolves/#findComment-2547814 Share on other sites More sharing options...
Max_Dammit Posted October 28, 2010 Share Posted October 28, 2010 Does that mean I could model, say, a GH swinging an Ork leg as a CCW? With an legless Ork on the base? Se no reason why not :) Link to comment https://bolterandchainsword.com/topic/214003-chain-axes-for-wolves/#findComment-2547846 Share on other sites More sharing options...
Bat33.1 Posted October 28, 2010 Author Share Posted October 28, 2010 Thanks for the replies ;) To paraphrase 'hell yes' anything goes... Hmmm a mark of the wulfen figure could be modelled wielding a melta gun by the barrel as a club? ;) Link to comment https://bolterandchainsword.com/topic/214003-chain-axes-for-wolves/#findComment-2547945 Share on other sites More sharing options...
Myxx Posted October 28, 2010 Share Posted October 28, 2010 Does that mean I could model, say, a GH swinging an Ork leg as a CCW? With an legless Ork on the base? Not only can you, but you should! I would love to see it! Same with the melta-club... Link to comment https://bolterandchainsword.com/topic/214003-chain-axes-for-wolves/#findComment-2547968 Share on other sites More sharing options...
